Simple Wood and Iron Pipe Tool
3,688
67
4
Introduction: Simple Wood and Iron Pipe Tool
About: I work wood but I also have studied chemistry
This is a quick (30 mins including glue curing time) and cheap (0 pesos) project.
I have a pipe and was in dire need of a proper packing/cleaning tool, so I made one. The tobacco box you see in the back was also the object of an instructables.
Let's go!
Step 1: Reuse an Old File
For the metal part, I used an old rusted file that I cut in two and cleaned up with a wire brush and on the beltsander.
This metal poker will be used for removing the charred tobacco that accumulates in the pipe's bowl.
Step 2: Insert in the Piece of Wood
I then inserted it in a dowel in which I drilled a slot with the dremel. I added a slice of a different wood with a small hole to hide the big slot and make for a better looking finish. I glued everything together with 5 minutes epoxy.
Step 3: Sanding on the Beltsander
There is no good picture here because it was moving fast, but you basically shape the whole thing the way you want on the beltsander. Mind your fingers! ;)
I kept the botttom part round and sanded it down to a diameter that would allow it to fit inside the pipe's bowl for packing tobacco.
Step 4: Finish
I finished it with a coat of a 2:1 paraffin oil:hexane mix, to give it a nice yet food safe finish.
(Total disclosure would be that I use nothing else than this finish. Ever.)
Thanks for reading!
Be the First to Share
    • Make It Bridge
      Make It Bridge
    • For the Home Contest
    • Game Design: Student Design Challenge
    4 Comments
    beardedchipmunk
    beardedchipmunk
    7 years ago
    really love l'aspect recyclage here....save those precious metals!
    beardedchipmunk
    beardedchipmunk
    Reply 7 years ago
    also, good luck smoking with the new tools! I just hope accelerating the efficiency of the whole process with these creative projects doesn't see too much detriment to ye lungs
    Me2free
    Me2free
    7 years ago
    That's a great looking pipe, did you make that also?
    deluges
    deluges
    Reply 7 years ago
    Ah, I wish. No, it's a medico churchwarden i bought in an antique store for 6 bucks. But now that I have a lathe (https://www.instructables.com/id/Drill-Press-to-Lathe-With-a-Bit-of-Scrap-Wood/) I'll probably turn my own pipes!
