Introduction: Simple Wrench Ring
Two ways to make a stylish ring from a wrench
Step 1: Supplies
Small combination wrenches (size ¼in or smaller)
Steel rods of differing sizes for different size fingers
Oxyasettling torch set with number 2 welding tip
Ballping hammer
Pliers
Vice grips
Welding gloves
Striker
Pedestal grinder with wire wheel
Step 2: Setup
Use appropriate sizing rod and attach wrench with vice-grips; and pliers.
Step 3: Shaping (1st Way)
Light welding torch and heat wrench while using pliers to bend around steel rod until wrench is completely wrapped around the rod.
Step 4: Shaping (2nd Way)
Attach wrench to steel rod with vice-grip and pliers. Then use pliers to bend wrench around steel rod.
Step 5: Removing/Polishing
Once wrench is shaped to desired size remove ring from steel rod with either pliers or ball-ping hammer. Run hot wrench under water then use pedestal grinder with wire ring to polish and buff the ring.
Step 6: Finished
Once ring has been polished you can use sanding paper to polish hard to reach places.
When finished wear the ring and show off your love of tools :)
