Introduction: Simple and Cheap Water Leak Alarm Sound and Light
Water Leak is a problem that can happen in almost every home. I made a simple alarm Circuit for water leak warning. I hope it works for you too.
• Mini plastic container (I've used a toothpick box)
• 2N2222, 2N3904 or any other NPN transistor
• 5mm Animated LED (You can get from a cheap ugly battery powered candle.) This Ugly Things
• 12mm Piezo Buzzer for Annoying Alarm (You can get from broken UPS or cheapp door alarm)
• M3x10 Bolts&Nuts
• Fork Terminal Cable Lug
• scrap cable
• 9V Battery
• 680R 1/4W Resistor
• 1K Resistor
Step 1: Prepare Container
Drill 3 hole bottom of the plastic container. Mount nuts and bolts together with cable lugs for water contact terminal. Solder cable to lugs for connect the circuit board.
Step 2: Solder the Circuit
Solder the parts according to schematics. After that install battery and the circuit board inside the box.
Step 3: You've Done. Test It
Test inside the sink. You don't need a Flooding ;)
