Introduction: Simplest Chunky Baby Blanket
Welcome to this heartwarming project were I'm going to guide you through creating a cuddly, custom-sized crochet baby blanket using the continuous granny square technique. This pattern is designed with simplicity and speed in mind, perfect for beginners or anyone looking for a quick and satisfying craft.If you enjoy this free pattern and are interested in more unique crochet projects, be sure to visit my Etsy shop. Let's get started!
- Fluffy Yarn: Choose your favorite color or a combination to make it unique.
- Crochet Hook: Suitable for the yarn weight you've selected.
- Stitch Markers: To keep your place and make counting easier.
- Yarn Needle: For weaving in those ends for a neat finish.
Step 1: Watch the Video Tutorial (Optional)
Before you start with the written instructions, consider watching this video tutorial. It can be especially beneficial if you're a visual learner or prefer to have a visual overview before beginning. The video serves as an excellent guide alongside the written steps.
Step 2: Starting Off
Start by creating a magic ring. This will be the center of your blanket and the foundation for your granny square.
Step 3: Crochet Foundation
Chain 2 (this counts as your first double crochet). Place a stitch marker here to remember this spot. Chain 1.
Step 4: First Round
Then, work 3 double crochets, chain 1, and repeat this set 2 more times into the ring. Finish this round with 2 double crochets and a slip stitch into the second chain of the initial chain 2 to close.
Step 5: Growing the Blanket
Move to the first chain 1 corner space with a slip stitch. Chain 2 (counting as the first double crochet again), mark it, and continue the pattern from the previous round. Each corner will have 3 double crochets, 1 chain, and then 3 more double crochets. Complete the round by working 2 double crochets into the first chain space and slip stitch to the initial chain 2.
Step 6: Expanding Further
As your blanket starts to take shape, continue by slip stitching to the first chain 1 corner space. Chain 2, add a stitch marker, and proceed as before, following the corner patterns. Each new round will have more side double crochets between corners.
Step 7: Expanding Your Blanket
Continue working in rounds, adding stitches as needed to grow your blanket to the desired size. This method allows you to easily adjust the size to your preference.
Step 8: Diagram
If you're a more visual learner, here's a diagram to guide you through each step of the pattern!
Step 9: Finishing Up
Once your blanket has reached the desired size, complete your work by slip stitching to even out the last round. Cut the yarn, leaving a tail for weaving, and secure all ends.
Step 10: Conclusion
Congratulations, you've now completed a beautiful, fluffy granny square baby blanket! This blanket not only provides warmth and comfort but also adds a touch of handmade charm to any nursery or home.
Remember: you can always vary the size and color according to your preference and needs.
