Introduction: Single Step Stairs
This project uses only one sheet of plywood. It makes a four level step that is 32 3/4 inch tall. I use mine for my kids (2 and 5 yr old) to get on to the trampoline, you can use yours for whatever. Hope you enjoy!
Step 1: Tools and Materials
Tools and Materials needed:
1 Sheet of 3/4 inch Exterier Plywood
Grid Paper
Pencils
Rulers
A Large Square (Makes 90 degree)
Wood Glue
Nails and Hammer
or Nail Gun and 2 inch long nails
Wood Screws (I used 1 1/4 inch Coarse Thread)
Power Drill
Pilot Hole tool (Makes room for the head of the screw and not crack the wood)
Screwdriver
Long Clamps
Sand Paper and Sanding Block
or Jitterbug or Orbital Sander (electric or pneumatic)
Hand Saw (I do not recomend takes way too long)
or Circular Saw and Jig Saw
Step 2: Planning
I reccomend you take some graph paper and a pencil and sketch out how to fit all of these parts onto one sheet of plywood. Use my design. For my graph paper I made each square represent 2 inches, that way a 4 x 8 ft sheet of plywwod is only 24 squares wide and 48 squares long. Here is a list of parts and sizes for each that you will need:
Piece Size In Planning Photo #
Mid - 32 x 32 (stairs are each 8 inches tall in a zig zag) - Photo 2
Right -(Steps 1 & 3) 32 x 24 x 8 x 16 (looks like a L with a large back) - Photo 2
Left -(steps 2 & 4) 24 x 32 x 16 x 8 (looks like a L with a tall bottom) - Photo 2
Bottom of R - 9 x 31 1/4 - Photo 3
Bottom of L - 9 x 23 1/4 - Photo 3
Back - 20wide x 32tall on L x 24tall on R x 10 1/4across at top - Photo 3
Front of 1 - 9 x 7 1/4 (I used this at the back of 1 for support) - Photo 4
Front of 2 - 9 x 16 (I used this at the back of 2 for support) - Photo 4
Front of 3 - 9 x 15 1/4 - Photo 4
Front of 4 - 9 x 18 (or longer than 18 if you have extra room) - Photo 4
Top of 1 - 13wide front x 17long x 11wide at back - Photo 5
Top of 2 - 13wide front x 17 long x 11 wide at the back - Photo 5
Top of 3 - Exactly the same as Top of 1 - Photo 5
Top of 4 - 12 x 12 - Photo 5
I realize you can not read my pencil marks on this pic, but you can see where to put each piece. You might can read the marks on the cut out versions better. For a better view of the pieces check out the next step: Cutting and look at Pic 1 and 2.
Step 3: Cutting
Take a pencil and mark up your plywood (all the pieces) on your board. Make sure they all fit (don't forget that the blade of the saw takes out 1/8 of an inch, so leave room! Use the graph paper. Then cut each piece and mark them on an edge or inside that won't show what piece they are (ie: Top of 1 or Bottom of R). There is a little bit of extra room on the sheet of plywood but try really hard not to make a mistake, else you defeat the purpose of making this out of one board. You can see from the the grain of the board in pic 1 that it is cut from one 4 x 8 piece of plywood. In pic 2 you can see them spaced out some.
I cut the Top of 1,2,3 and 4 out square and I tell you in the next step how to round off the edges. Leave plenty of room for that!
Step 4: Mock Up
After all the pieces are cut, I would start by using clamps and putting the pieces together and see how they fit. Do not glue or nail or screw, just place them together with clamps to make sure everything fits (pic 1). Before this shot, I took the Top of 1 2 3 and 4 and used an old coffee can(6 inch diameter) or what ever gives you a nice curve and cut the edges off the corners of all the Tops (or steps). On Tops 1 and 3 (both of these are exactly the same) the front two edges are rounded off and the back right edge but not the back left corner. The back left edge or corner has 8 straight inches till the start of the curve to the outer side. Then on Top 2, opposite from 1 and 3, take and round off the front two corners and the back left. Then on the back right edge come 8 inches up toward the front and make you curve ( pic 1).
Step 5: Building
Once you got everything how you like start with the Mid and a side, I started with the left. Get the Mid and the Left and the Bottom of L and the wood glue and screw them together (pic 2). I used corner clamps to make this easier (I forgot to put these in the original pic, sorry) The two screws you see here will be covered up by Bottom of R. Pic 2 shows the Front of 2 where it is suppost to go, if you want these steps enclosed. It was at this point I decided not to cut holes in the side of this project for shoes and leave the Front of 1 and 2 off, but then I figured I needed the support, so I but them at the back of the steps (pic 2 and 3).
The next piece I put together was the Front of 2 and 4. Then I put on the Bottom of R and the Right side. Then the Front of 1 and 4 (yes if you do it my way (leaving a place to put shoes under Steps 1 and 2) the Fronts overlap). see pic 2 and 3. I would use glue and screws where ever possible and then nail it together with a nail gun just for more support. I left the Tops last and the back for very last.
Step 6: Paint
I choose to seal the steps with Thompson's because it will sit outside and needs to last at least till the kids are big enough to climb into the trampoline themselves. You could paint it up any color, or one idea I had was to take it to a shop and have it sprayed with truck bed liner! That would make it last, have it Rhino Linered! You could add a stain to the seal if you wanted.
Step 7: Enjoy!
Enjoy! Here are a few shots of the finished project.
43 Comments
12 years ago on Step 7
Very nice indeed! Certainly cheaper, better-looking and more versatile than actual trampoline ladders tend to be.
I almost want to say that 'form has followed function', but it hasn't - the two go hand-in-hand here.
I think the tops/treads have a slightly 60's retro look about them.
And storage space, too!! That's great for when the kids have run off indoors without their shoes...
The only fly in the ointment for me is my inner pedant wondering why they're called 'single step' stairs... I mean, there are 4 steps/treads to them, and you've used 7 steps for this Instructable - or maybe I'm missing something?
Reply 3 years ago
I think it means one foot steps, versus a ladder or actual wide steps.
Reply 12 years ago on Introduction
What a great instructable!
My interpretation of "single step" :
each tread is meant for a single (adult sized) foot.
Thanks! I think you sumed it up the best. Each step is made for one adult sized foot, however in this case I just increased the size as much for the top area and still use just one sheet of plywood. I thought that might be safer for the kids. Who knows I might could have made each step and made another step?
Reply 8 years ago
Cheers!
Hmmm! - Sounds plausible, thanks.
they are called that because when you use them you take one step per lever rather than two with traditional stairs
Sooo..., 'traditional' stairs are/were a LOT deeper (front-to-back) than the ones in every house I've ever known?
Presumably something to do with not over-taxing the rich with such steep flights to reach the next level (and probably very quickly became status symbols)?
Hmmm... Thinking about it, that would account for the 'sweeping' staircase that so many films used to show...
So, thanks, nicknewbie.
sarcasm doesn't work when you don't understand what your being sarcastic about presumably something to do with not over-taxing the rich
Sorry, that wasn't actually meant to be sarcastic - I was typing what I thought, as I thought it, and not re-reading and editing it enough.
I should have said (having slept on it) that manor-houses etc., afforded more room for grander staircases, which some designers and/or Lords-of-the-manor may have (partly) justified as a way of not over-stressing their hearts - though everybody knows/would-have-known that that would have been, at best, a secondary concern.
Again, sorry about the mix-up.
8 years ago
The design was spot on. My cuts were a little off, but it came together well. Cheers!
Reply 6 years ago
Very Nice! Looks great.
Reply 8 years ago
Thanks to the measurements revised using Sketchup by Haley in the comment below
8 years ago on Introduction
I think that with a little tweaking, this would make a cool cat tree as well!
I note that your trampoline has safety features to protect your children from falls from this "toy". Do think that maybe a hand rail of some sort would also be beneficial. I know that some homeowners insurance policies do not like trampolines and have been known to cancel policies. There are times that I feel that pools are safer that trampolines. I highly recommend the consulting with your insurance company before venturing into installing either.
I thought about a hand rail but the whole thing, steps, kid and all, might fall over because of the weight. If the child stops up top and leans to one side with the hand rail I thought it might tip over. I guess I could put one on each side and that might balance it out.
I can't climb up a four inch curb without a handrail - but folks like me tend not to trampoline either. It is such a beautiful structure; if your kids don't want a handrail please don't feel you have to add one just because it seems like the sort of thing one ought to do. Trees and hills and boulders rarely have handrails but children enjoy them!
Reply 8 years ago
I built these steps. I'm 275 lbs. I can stand on the top step with only one foot. It's sturdy and safe. Cheers!
8 years ago
8 years ago
