Six-Axis Stewart Platform
12,133
68
5
Introduction: Six-Axis Stewart Platform
Overview:
What follows is part 1 of 2 for the build of a 6-Axis hexpod robot inspired by the work of D. Stewart, and implemented to be built by off the shelf parts and controlled via Arduino. This first instructable includes the design files for rapid prototyping (via laser cutting and 3D printing), a list of material and hardware links for sourcing parts, and an introduction to the electronics setup for PWM control. This platform was developed to precisely control heavy loads therefore choosing linear actuators over a converted servo design. Not locating an instruction guide for a design of this kind anywhere online, I hope this instructable provides a starting off point for anyone with similar robotic needs.
The second installation of this instructable will outline the inverse kinematics and control interface.
Step 1: Parts - Electronics Hardware
Disclaimer: All hardware images are courtesy of Servocity unless otherwise noted.
With the linear actuator rigged for PWM control snip the wire off after the control box before the supply end and re-wire the power & ground to the DC Barrel Power Jack. The actuators with PWM control have a built in resistor to stop any power overloading on the board. Therefore the Barrel Jack goes straight to the actuator and the digital input is powered by the Arduino board 5V power.
Step 2: Parts - Robotic Hardware
  • Lightweight Mounting Bracket for Linear Actuator (x9)
    • Bushings and basic hardware come with
  • Swivel Hub (x9)
  • 6-32 Screws (Get prescribed length for your material of choice)
    • These are for attaching robot hardware to laser cut design and mounting of your needs
Step 3: Design Laser Files + Gimbal Joint Design
Note: All laser files were optimized to be cut on a bed of 32in x 18in, and 3D Printed parts optimized for a bed of 8in x 8in x 10in.
Materials:
  • 0.125in Acrylic
  • 0.25in Acrylic
  • ABS Filament for Gimbal Print
Attached and available for download are the laser cut files and gimbal joint that connects two separate actuators to a single point at the bottom of the platform. This eases the computation during control maintaining a triangular platform and parallel lengths of connected actuators.
The 3d model attached outlines the assembly steps and illustrates how each parts relates. Please contact with any questions, issues, or suggestions!
Be the First to Share
    • Sculpt & Carve Challenge
    • On a Budget Challenge
    • Backyard Contest
      Backyard Contest
    5 Comments
    agungpambudi55
    agungpambudi55
    4 years ago
    Introduce myself, my name is Agung Pambudi. I'm working on stewart platform robot 6 DoF with 6 Firgelli L16P linear actuator. I am confused with kinematics for inverse and forward and confused with modeling for stewart platforms. I'm have searched for paper but not found can I easily understand and how can put into the program. Do you have reference simple for kinematics and dyamic modeling this? Thanks.
    nozeid
    nozeid
    6 years ago
    hi
    what kind of sensors did you used ?
    MichaelC87
    MichaelC87
    7 years ago on Introduction
    What kind if linear actuators did you use for this?
    What kind of cost to build does this come out to (estimate) ?
