Size Markings for Wrenches and Sockets
Intro: Size Markings for Wrenches and Sockets
I did this on Craftsman wrenches and socket sets of various vintages ranging from my father and grandfather's to current. Most had deep engravings of the tool sizes. It was more difficult to get it to work with very fine markings found on some of their smaller 1/4" drive socket wrenches. Some of the finer markings required more than one attempt. I'm not sure how well this works on laser etched tools that became available in more recent years. I would think that quickly wiping off the paint with a dry towel will work, but the effect would be more subtle. The good thing is that I could completely clean off the paint with lacquer thinner if the results were not to my liking.
Materials
- Hand tools to mark
- Oil based paint marker, avoid extra fine tip if possible. Sharpie oil markers work well. Optional: Contrasting colors to suit your categorization needs.
- Shop towels or rag
- Lacquer thinner
Reasons to do this
- Make it easier to spot the right tool size quickly.
- Using contrasting colors make metric and US/SAE tool sizes easier to differentiate in a pile of tools while I am in the middle of a job, particularly if I'm not returning them to their storage locations right away.
- Looks nice and is customized to you
- Cheaper than buying a certain name brand that offers enameled lettering
STEP 1: Prep Work
Clean off heavy dirt and oil deposits from the tools with a towel and some lacquer thinner, acetone or other solvent that evaporates quickly. They don't need to be clean enough to eat off of, just clean enough to allow paint to adhere well.
STEP 2: Apply Paint
Scribble over the size markings with the paint marker. You want to lay on the paint fairly thick. I started with one tool to see how the color turned out, then worked in batches of 20-30 tools.
Allow the paint to dry for a hour or two.
Note: I used two contrasting colors to differentiate between metric and US/SAE tool sizes. You could also use one color for the lettering and another for the size. It's really up to you on how to customize your tools.
STEP 3: Removing Excess Paint
Apply a small amount of lacquer thinner to a shop towel. I had a spot about 1 - 1.5 inches in diameter. Lacquer thinner flashes off rather quickly so soaking the towel will just be wasteful and make excessive fumes.
Gently dab the dried paint once or twice to soften the surface. I found rolling the tool through the moistened towel works the best. Ideally only the surface paint is softened up while the material down in the crevices remains relatively dry. You should still have seemingly heavy deposits of paint on the tool surface, this is okay if you work quickly.
Note: You could just wipe the paint with the lacquer thinner, but it seemed to strip too much out of the crevices. If this happens just mark over the surface with the paint marker, allow it to dry and make another attempt.
Wipe the excess surface paint off of the the tool with a solvent free part of the shop towel. Most if not all of the surface paint should come off with a few seconds of rubbing. A hard object finger nail or small piece of wood like a Popsicle stick backing up the towel can help. Note how there is a bit of paint remaining on the surface in the picture. It should come off easily if you work quickly while the paint is still softened.
STEP 4: Cleaning Up
Clean up any stray paint that made its way into the roughened areas of the tool with a bit of lacquer thinner.
Dispose of the rags as directed by the lacquer thinner can.
Allow the paint to dry for a few hours to ensure it doesn't smudge.
50 Comments
navarro1950 5 years ago
BrianA217 5 years ago
I LOVE THIS! I have used a dot of colored nail polish on the flat end of a drill bits to keep sets together for YEARS. Why the heck didn't I think of doing it on WRENCHES. I know it's two years old but thanks, it's a great idea.
TallTrav 7 years ago
I'm a repair tech for medical equipment. Went through a whole 5S (workplace organisation process thing) recently. I was in charge of doing the tooling (organisation, purchasing, storing etc) so I did this to the sockets and wrenches. My boss didn't like it. The techs loved it. The boss threw a fit and had me clean it all off the tooling. When he retires, it's the first thing I'm doing. Some folks will never change...lol.
make-it-mike 6 years ago
I'm with you. What possible downside could there be to making the markings easier to read??!? Any manager/supervisor worth their salt should welcome ANY cost-effective way to improve efficiency.
When the marking is done with a bit of care, IMHO the tools will even look BETTER than they did before... as well as being more useful. There's just no figuring some people. *SMH*
slice73 7 years ago
I'm currently in the process of doing this thanks to your instructable. I decided to go with model paint and it's working out great. Pictures to follow!
MichaelT177 7 years ago
Instead of using paint.Why didnt you use a crayon or an artist Litho Wax pencil? I have been doing that for years. Eversince the late 70s or early 80s if you were into Dungeons & Dragons and you bought any of the games. The dice would come with a small white or yellow crayon to use on the dice to be able to read the etch markings on the dice better. I have always used a white or yellow crayon on my tools from wrenches, sockets especially the smaller ones and drill bits. Makes it easier to read. I found that white, yellow or red is best to read on tools.
af11641450 7 years ago
I too have been doing this for years, I use a paint crayon used to mark prices on windshields of cars for sale, it never comes off.
yep that works great to I couldnt think of what they were called. But I know that both the crayon and Litho Wax pencils you get in a art supply store both are made from beeswax and they work great to
mountainfish 7 years ago
ScottM100 7 years ago
DiyWaterDog 7 years ago
have you tried to mark drill bits. Those are the ones that drive me nuts. Sometimes I think I'm as blind as a bat.
mc2517 7 years ago
How about using some fine grit alum-oxide paper to sand off the flats. Great piece of advice!!
RUSmiling 7 years ago
IanJC78 7 years ago
Great idea. How about we use what most of married men have in the house. Nail polish and remover. Between my kids and wife, I can mark the world.
wastubbs 7 years ago
Heh, after a couple uses of a fresh wrench, I end up doing the same thing with moly grease instead of paint!
NihilFB 7 years ago
Excellent idea - I will give that a go with the socket set first because that's the one I find I have to peer at in order to see which size it is.
bd5 7 years ago
Aw man, I did this years ago, I still do. 'Never thought to make an instructable out of it!
jimvandamme 7 years ago
I wrap colored tape around sockets and wrench handles. It cuts down the sorting by 50%.
NihilFB 7 years ago
We use coloured LX tape around tool handles backstage so that all of the techs can keep track of the spanners, screwdrivers, hammers, wire-cutters, whatever.
PhilipH4 7 years ago
I own a set of Metrinch sockets and wrenches. Each of them fits both SAE and metric.
