Introduction: Sizzix Big Shot Bearing Replacement
This Sizzix Big Shot was not cutting out the paper properly on both sides. The right side, closest to the crank handle, was not applying enough pressure to the cutting die. This suggested to me that the rollers had become misaligned and most likely was cause by a damaged bearing. Time to disassemble and determine the problem.
Step 1: Tools
For disassembly you will need the following tools:
*Allen Wrench that came with the Big Shot to remove the crank handle
*Phillips Screw Driver
If you do need to replace the bearings you will need:
*Hammer (I like to call them persuaders) A medium size should work fine
*Bar of brass or aluminum to hammer on, so we don't deform the steel rollers
*Snap ring pliers, to remove those pesky snap rings
*Calipers, mm scale is preferred
Step 2: Dissasembly
Remove the allen screw holding the crank handle then remove the crank handle.
Now turn the machine upside down and remove the 4 large phillips screws in the middle section.
Remove the 8 small phillips screws along the left and right sides.
The 8 screws on the back and front do not need to be remove but if you want to go for it.
Now carefully pry the plastic sides off. They are attached with clips to the in-feed and out-feed table so be careful not to use to much force and break these. Ofter removing the sides the tables should slide out nicely and then the top and bottom plastic shields should be easy to remove from the roller frame.
Step 3: Inspection and Diognosis
Now look at the rollers and bearings. Does anything seem wrong or broken. Looking at this one you can see that three of the ball bearings have the metal shields still on them but the one near the crank handle has the shielding popped off. When I first took this apart the bearing was pushed halfway out of the frame also. This is the cause of our problem. The bearing failed and caused the rollers to become misaligned, they no longer run parallel to each other and exert less pressure on the side with the failed bering. This will need to be replaced.
Step 4: Remove the Bearing
Now to remove the problem bearing so we can measure it for a new one.
First remove the metal gears. Using the snap ring pliers remove the two snap rings. The gears will then slide off the shaft. Place these in a safe place.
Now on the left side the shafts are held in place by two metal plates. Remove the four phillips screws and slide the plates until they are out of the groove on the the end of the shafts.
It is time to use some persuasion to remove that bearing. Place the brass bar on the end of the roller as show in the picture. Make sure you are on the opposite end of the problem bearing. We want to push this bearing out. Using a hammer strike the brass bar to push the bearing out slowly. You may need a bigger hammer or more force, the small hammer originally picture was too light for this job but the medium hammer worked nicely.
Measure the bearing so we can find a replacement. This one measure 12mm ID, 30mm OD, and 9mm Width. Looking on McMaster-Carr and Granger this appears to be a non-standard size. I incorrectly ordered a 10mmx30mmx9mm bearing when I originally looked at this machine. The shielding has the number 6200ZZ and a quick search on McMaster gave me that size so without measuring I ordered 2, don't make this mistake, measure it before you buy a replacement. I search on eBay for "12x30x9 bearing" and there was one seller in China with the size I need for $5.
Here is the eBay store:
Step 5: The Bearing
I though it was interesting to look at how this bearing failed.
Since the shielding was easy to remove we can look inside at the ball bearings. From the picture you can see that the bearing cage broke and all the balls were able to group together where they jammed each other up. The center of the bearing no longer rotates. With one side lacking any ball bearings for support the roller was able to deflect when cutting and could not provided enough pressure to the cutting die.
Step 6: Putting It Back Together
Now that we have our bearing check to make sure it is the correct fit on the end of the shaft. Also make sure it will fit correctly into the frame.
Place the rollers back into the frame and start the bearing. Using the brass bar and hammer gently tap on the bearing while making your way around the outside. You want it to go in evenly so that it does not bind on the shaft or damage the bering. An arbor press would be useful here. Once the bearing is in place make sure everything moves freely. Now to reassemble everything.
Reassembly is the same as disassembly just in the opposite direction.
Step 7: Test the Repair
Get a cutting die and try out the repair job. The die now cuts on both sides like it did when it was new!
17 Comments
Question 8 weeks ago on Step 6
where can I get a new bearing for a sizzix big shot
Question 1 year ago
Hi, your article was very easy to follow but ...now that I have my sizzix apart I can't get the bearing out! I have followed you instructions but I only have two hands making it impossible to keep it still while I hit it! How did you do it? Any hints/tips? Also how far out does it come and do I replace both sides? If so how do I get the other side out. I hope you can help me and that you can decipher my questions. Thanks
2 years ago
My hotshot is only cutting at the edges. Is this because the plates are warped ? The roller worn? Any suggestions gratefully received thanks
Question 3 years ago
what is the distance between the rollers?
8 years ago on Introduction
where can I find spare parts? I broke the roller frame !!!!
I didn't have any luck with a google search and didn't see any parts on the Sizzix website. You could try contacting customer support.
Reply 4 years ago
hai l'indirizzo dell'assistenza? Grazie
7 years ago on Introduction
I called the Sizzix company and they offered to send me all of the replacement parts at no charge. :)
Reply 4 years ago
ciao...puoi dirmi la email per richiedere gli ingranaggi che sono rotti? Ti sono arrivati, hai risolto? Grazie
That's good to know that they have good customer service and parts. Thanks for letting us know!
4 years ago
Hey there very informative post. I have a question i opened my bigshot as it was not cutting paper properly. Pressure problem.mainly on the left side. But the bearings are okay I don't see any problem with them they look absolutely fine. Any idea why my machine is not cutting paper proply and why it has pressure problem??
Reply 4 years ago
Is the frame bent in anyway or is there damage to the rollers? Maybe the holes in the frame that hold the bearings are deformed? Measure the distance between the rollers with a caliper if possible, if your problem is related to the machine then on the left side the rollers should be farther apart, it may be a small amount. If it does not seem like something you can easily fix see if you can add some shims around the left side of the bearings to bring the rollers closer, aluminum foil works good as shims or even thin paper. Good luck!
5 years ago
I am looking where to get an allen key and screw and washer for my Sizzix Big shot handle. Please can you help me? Thank you in advance.
6 years ago
This is very interesting. I broke the little handle gear last night and took mine apart. Thankfully I did not break the bearing thingies! I would have had to call my brother. I emailed Sizzix and hope they send me the gear soon. Ugh, two layers of denim on the tattered florals die. Is this the only die that breaks a Big Shot? LOL!!!
7 years ago
Thank you for providing these instructions showing how to fix a Big Shot! I couldn't find any other info online about disassembling one. After taking apart my Big Shot, I see that I need to replace my ball bearing. Where can you buy a brass or aluminum bar?
Reply 7 years ago
Thanks! You sould be able to find an aluminum bar at any home improvement store such as Lowes, they have them in the hardware section. If you can't find a solid bar, tube will work fine.
This is very helpful to learn how to take it apart!!! My handle broke. I'm hoping to find parts, too!
