Introduction: Skate Box With Side Rail
6 feet long 22 in wide 10 in tall
Step 1: Materials
We took a 42x48sheet of plywood and we cut it in half and made one piece 22”x24“ and the other half we made 22”x48”
Step 2: Materials
We took 6 scrap pieces of 2x6 and we cut them 4 of them we kept the same length And we didn’t cup them but 4 cut 3” off of our extra 2x6 to give it more hight then we cut 4 20” pieces for the width.
Step 3: You Put It Together
You shape out what you are trying to do first then you take 2 of your 20” pieces and you put it at the end of Each side then you take your 2x6 and you make a rectangle with it then you put 8 screws in too keep it sturdy
Step 4: The We Took These 3” Squares to Make It Higher
The we took these 3” squares to make it higher We drilled a hole first then we drilled a screw in you do that for each square
Step 5:
Step 6: Repeat the First Step
Do the same thing for the top of the box
Step 7: Attach It
Take a screw and drill it into the 3” square do that 3 more times
Step 8: Attach the Plywood
Take the plywood and attach it to the top part of your project I used a nail gun but you can you a drill if you have too
Step 9: Last Step
Attach the side rail with a couple screws I used 14 in total
