Introduction: Skull 3 in 1
This is my entry into shogun jimi's skull challenge 2017.
I made a skull with inlay Pendant / Magnet / Key-ring.
All hand carved from a bit of scrap wood.
I hope you enjoy!
Watch the build - https://www.youtube.com/channel/UCRMjvilGRdZxHqr34...
Follow my work on instagram - https://www.instagram.com/ggwoodproje...
Help me make more projects- https://www.patreon.com/GGWoodwork
OR
One time tip -https://www.paypal.me/GGwoodwork
Check out Jimi's Channel - https://www.youtube.com/user/shogun21jimi
Check out the comp. playlist - https://www.youtube.com/playlist?list=PLp1gai6Qjne...
Thanks GG
Step 1: Hand Carving
First step is hand carving, i found myself a piece of scrap that i wanted to use for this, and drew out a skull shape (or as good as i could draw skull shape anyway) and used my small v gouge to carve out the skull shape and details.
Step 2: More Detail
I wanted to add more detail into the skull so i drew out some eyes etc and tried to carve those out as best i could.
Step 3: Milliput
To add more contrast and make the skull a bit more interesting i used some black and white milliput epoxy to inlay the carving.
Step 4: A Whole Lot of Sanding
I removed the excess milliput by sanding it down with 60 grit paper,
Then i moved from 80,120,240,500 and finished up at 1,200
Step 5: Cut to Shape and More Sanding
Next i cut the skull down to size and shape and went through the sanding process again
Step 6: Magnet
To try and hide the magnet i chiseled out a small recess in the back of the skull making sure it was deep enough to hide the magnet. To cover the magnet i made a small thin cover and super glued it into place.
Step 7: Finish & Hook
Next i moved onto finishing the skull.
I used some clear coat poly finish applying about 4 coats front and back.
To Attach a hook i drilled out a 3mm hole in the top of the skull and super glued half of a lobster clasp in place.
Step 8: Job Done
Thats it a 3 in 1 Skull.
Its not perfect but i like the fact its not perfect.
A huge thanks to Jimi for putting the skull challange on there has been some amazing projects made.
Check them all out here - https://www.youtube.com/playlist?list=PLp1gai6Qjne...
Also show Jimi some love - https://www.youtube.com/user/shogun21jimi
I hope you enjoy!
Please leave a like, share & comment. And subscribe for more like this!
Watch the build - https://www.youtube.com/channel/UCRMjvilGRdZxHqr34QKzB_Q
OR
Thanks GG
