Introduction: Skullcandy Dime TWS Manual & Pairing Guide
The smallest, lightest earbud we’ve ever made packs a powerful punch. Skullcandy® ultimate sound gives you the kind of full, rich sound you’d expect from far more costly earphones. Even when you’re on the phone, you can use either earbud alone thanks to the dual microphones. Dime is sweat- and water-resistant, so it can withstand workouts and outdoor excursions, and it’s covered by our Fearless Use Promise, so you can listen without stress.
What’s in the box
  • True Wireless Earbuds
  • Charging Case
  • Ear Gels (S, M, L)
  • Micro-USB Charging Cable
  • User Guide
Step 1: Setup Dime Earbuds
Time needed: 3 minutes.
Setup you new Skullcandy Dime Earbuds
  1. Remove the Earphones and Stickers to start charging
  2. Remove the earphones from the case and clean the charging contact points of stickers. Before using the earphones for the first time, we recommend charging them for about 30 minutes in the case. Make sure the earphones’ LEDs glow red to signal that they are charging.
  3. Once charged, remove from the case
  4. Remove the earbuds from the case once they’ve been charged to begin pairing. Both earbuds will turn on automatically, and the LEDs will glow blue at the same time as they sync.
  5. Enter pairing mode
  6. You’ll hear a voice prompt that reads ‘Pairing’ once the earbuds have synchronized up. The left earbud will be the only one to begin flashing red/blue. Turn on Bluetooth on your device and seek for ‘Dime®’ in the list of accessible Bluetooth Devices. If your buds don’t automatically enter pairing mode, hold the button for 4 seconds.
  7. Pair with your phone
  8. You’ll hear a voice prompt that reads ‘Pairing’ once the earbuds have synchronized up. The left earbud will be the only one to begin flashing red/blue. Turn on Bluetooth on your device and seek for ‘Dime®’ in the list of accessible Bluetooth Devices.
Pairing the New Device
Following these simple steps, you may quickly link to another device if you have already set up and paired to one.
  1. With a 4-second button hold, turn off your headphones manually.
  2. Press and hold both earbuds for 4 seconds while they are turned off. This will turn your earphones on, sync them, and then put them into “Pairing” mode. Your LEFT earbud will begin to flash red/blue at this point.
  3. To pair your new gadget, simply search for and choose Dime® from your available Bluetooth Device list.
PAIRING ISSUES?
ISSUE:The biggest challenge with true wireless earbuds is ensuring your buds are properly connected to each other and your device. There are times when you may unintentionally disconnect your buds and change their paired state; this can create pairing challenges and impact your ability to hear audio in both earbuds or use either bud in Solo Mode. Do not worry, we have a few easy ways to get this fixed!
FIRST COMPLETE A POWER CYCLE by simply placing your buds into the charging case until the LED on both earbuds turns RED. Then remove your buds from the case and evaluate, sometimes this is all you need, but if you’re still having trouble we’ve got you covered.
SOLUTION 1: RE-SYNC YOUR EARBUDS – “AUDIO ISN’T PLAYING FROM BOTH OF MY EARBUDS”
  1. Power ON your earbuds by removing them from the charging case, or manually press and hold the button on each bud for 2 seconds.
  2. Once powered ON (you can be in a connected or non-connected state) press the button on BOTH buds 4x to start the earbuds re-sync pairing mode (earbuds connecting to each other).
  3. Your earbuds will flash Red/Blue momentarily as they re-sync, once successful they will flash Blue together and you will hear a “connected” voice prompt.
  4. If you were connected to your device, your earbuds will automatically reconnect to your device and you’re ready to stream in stereo audio (sound will play from both earbuds).
 SOLUTION 2: RESET YOUR PAIRED DEVICE LIST – “I CAN’T GET MY EARBUDS TO PAIR TO MY DEVICE CORRECTLY, OR SOLUTION 1 ISN’T FIXING MY AUDIO PLAYBACK”
  1. To ensure ease of re-pairing, please un-pair or forget your Dime® in your paired Bluetooth device list
  2. Remove your Dime® earbuds from the charging case and allow them to automatically power ON.
  3. Ensure your earbuds are in a non-connected state, then on either earbud, press the button 2x and then hold for 2 seconds.
  4. This will automatically reset your paired device list and enter you directly back into Pairing Mode. You will hear the voice prompt “Pairing” and only the LEFT bud will begin to flash RED/BLUE.
  5. At this time, turn ON your device’s Bluetooth and look for “Dime” in your list of Available Bluetooth devices, and select it.
  6. IMPORTANT – Select the “Pair” and “Ok” prompts that will pop up on your screen.
  7. Once successfully paired, a voice prompt will notify you are now “Connected”
Step 2: User Controls
  • Auto Power On & Power Off:
  • Remove earbuds from Case, and Place them back into the case (charging will begin).
  • Manually Power On:2-second hold
  • Manually Power Off:4 Second hold
  • Play/Pause & Answer/End Calls:1x press on EITHER earbud
  • Volume Up:2x press on your RIGHT earbud
  • Volume Down:2x press on your LEFT earbud
  • Track Forward:1 second hold on your RIGHT earbud
  • Track restart/ track back:1 second hold on your LEFT earbud
  • Activate Assistant:3x press on EITHER bud
Auto Pair Mode
Charging
Earbuds
Case
Step 3: Frequently Asked Questions
What is the total charging time?
EARBUDS:
  • It takes an hour for the earbuds to charge to 100% within the case.
  • Place your earbuds in the charging case to charge them. While charging, the earbud LEDs will be solid red.
  • When the LEDs are fully charged, they will turn off.
  • A voice prompt will tell you that your battery has less than 30 minutes of play time left, and the LEDs will blink red every 5 seconds.
CASE:
  • It takes 5 hours for the case to charge to 100%.
  • Connect the Micro-USB charging cable to a computer, wall charger, power bank, or 12-volt adaptor in a car to charge your case.
  • When the case is charging, the LED to the left of the micro-usb connector will glow RED, and when the case is fully charged, the LED will turn Green.
Is it okay for me to wear Skullcandy dime in the shower?
The Jib True Wireless earbuds are sweat and water resistant to IPX4 standards. That is to say, they are not waterproof.
Is it possible to connect Skullcandy dime to several devices?
Multipoint allows you to connect to and switch between multiple Bluetooth devices. You can effortlessly switch calls from one device to another without having to disconnect and reconnect manually, for example.
Is the Skullcandy dime noise-canceling?
There are no sophisticated capabilities, like as active noise cancellation, and no app support is available. You may, however, use either earpiece separately, and the earpieces are water resistant to IPX4. Even considering the size of the box, the Skullcandy Dime’s battery life is disappointing.
