Introduction: Skully the 8 Bit Organizer
- Do you wear glasses/sunglasses?
- Do you own a desk or other solid structure on which you can place articles?
- Do you have pens, pencils, markers, tape, sticky notes, cutters, USB memory drives, glue, pink junior dirt bike gloves or any other miscellaneous junk you need organized?
If you answered "Yes" or "I think so" to the above 3 questions then you might want to partner up with Skully the 8 Bit Organizer for placement on your preferred "solid structure".
You can grab my 3D model here: http://www.123dapp.com/123D-3D-Model/Skull-Organizer/645137 and use the free 123D app by Autodesk here: http://www.123dapp.com/123d to mod if you like and then export to your preferred format for 3D printing; here is a sample workflow I have used at home designing and printing with great results: https://www.instructables.com/id/Basic-workflow-for-3D-design-in-Sketchup-and-3D-pr/
Skully has been designed to print on small build platforms so any home printer will have success printing. The placement of the parts in the 4 stl files attached produce Skully's parts even with less than perfect printer/slicer settings.
Instructions:
- Download my source file above (or use my pre-pressed stl files and skip to step 5)
- Open in your chosen 3D editor
- Make any changes you like to my design
- Export it to an stl file (or your printer's preferred format)
- Slice model (make G code)
- Print! (The source file has all pieces ready, I have also attached pre-processed stl files you can feed directly to your slicing software and should fit even tiny build platforms.)
- Color/outline with a sharpie (if you like)
- Insert neck collar into organizer base
- Insert neck cylinder into collar
- Mount head to neck cylinder
- Insert left and right crossbones/glasses perch
- Insert nose/glasses bridge perch
- Fling some pens/whatever into the tray slots
- Find a high utility position for Skully to setup camp
- Enjoy watching peoples faces when they inter your office and take notice of Skully
- See how long it takes office visitors to give up and inquire "what in the world is that on your desk?".
If you are thinking about getting into 3D printing at home check out some of my other Instructables complete with source files for your hacking enjoyment: https://www.instructables.com/member/megaduty/
If you like any of my projects please vote for me in the "Make It Real Challenge" using the vote button in the top right of the page. Thanks a ton for your votes!
Make On!
