Introduction: Skyline Sound Diffuser - Wall Art
Hi there! In this project I will show how to build this nice-looking skyline style sound diffuser out of wood. This type of sound diffuser does not absorb the sound, but instead randomizes the shape of the echo to create a more natural sound. I mostly use it as wall art, but it does provide some sound improvement for recording in that room.
This project is simple to make.
If you like the video or the project, please subscribe to my YouTube channel.
Supplies:
- 4x4 lumber
- latex paint
- paint roller
- 2-1/2" cabinet screws
- wood glue
Tools:
- trigger clamps
- cordless dril
- impact drive
- miter saw
- 16 gauge nailer
- 2-1/4 hp router kit
- table saw
- 10" combination saw blade
(Supplies links are Amazon affiliate links)
Step 1: Cut the 4x4s Smaller
It is important for the pieces to be square and for them to be all the same size. Dimensioned lumber is often not exact, or not square, so the first step is to cut the 4x4 lumber down to 3"x3". If you have a jointer, joint the piece square first.
Set the tablesaw fence to 3". Because this lumber is very thick, it is good to cut it in two passes with the blade cutting through about half of the workpiece on each pass.
Step 2: Square Up the Lumber
If you already used a jointer, you can skip this step. I don't have a jointer, so I clamped four of the pieces together and handplaned them as a group. This ensured a consistent size and a square edge.
Step 3: Paint the Lumber
Set the lumber on sawhorses and use a paint roller to paint one side of the pieces, rotate by 90°, then paint the adjacent side. Once these two sides have dried, rotate the pieces and paint the remaining two sides. I used the same color as the wall, which is a nice look, but use any color you like.
Step 4: Make a Temporary Fence for the Miter Saw
Attach a temporary fence out of scrap wood to the miter saw. Then make markings from 1" to 4" on the fence. This will act as a zero-clearance fence and prevent tearout during the repeat cuts.
Step 5: Slice All the Pieces
First cut off the end of each piece of lumber, to get a clean square end.
Use the markings on the temporary fence as a guide, and try to cut an even distribution of various lengths. For example: 1/2", 1", 1-1/2", 1-1/4", 1-3/4", 2", 2-1/2", 3", 3-1/2".
Step 6: Place the Squares
Place the cut pieces onto a piece of plywood the size you want the diffuser to be. Then arrange them in the way you want, with the end grain facing up. I tried to simulate a random arrangement for the pieces. Once you like how it looks, remove them one-by-one and number the bottoms with a marker.
Step 7: Glue the Pieces On
Using the numbering to put them in the right place, squeeze out some glue in the shape of one column of squares. This should be done one column at a time so it doesn't dry. Do not spread the glue; it will grab the end grains better if it is lumpy.
Step 8: Remove a Few of the Pieces
While the glue is still wet, remove some of the pieces so you can access the plywood. These should be some of the taller pieces, so they are easier to grab.
These empty spots will be used to screw the artwork to the wall. These pieces should be removed from columns that are 16" from each other, so it can be mounted to the wall studs.
Step 9: Nail It From the Back
If you have a finish nailer, once the glue is dry, lean the piece up onto one edge and finish nail through the back into the taller pieces. This will help to reinforce the piece.
Step 10: Screw It to the Wall
Prop up the piece where it will live on the wall, or attach a support cleat to the wall studs and rest it on that, and then attach the plywood through the empty spots using 2-1/2" cabinet screws. The cabinet screws have a washer head, which will distribute the force and hold the piece better.
Step 11: Replace the Missing Pieces
Place the removed pieces back in their spots to cover up the cabinet screws. They should fit very snugly on their own, but if they are loose, you can add a magnet on the back to stick to the screws.
Step 12: Cut a Cove Moulding (optional)
Using a cove bit in the router table and multiple passes, cut a cove moulding. Start with a piece that is much wider than necessary, and then cut off the cove part on the table saw after it has been routed. This makes it safer and easier to cut the cove on the router table.
Step 13: Cut the Miters
Measure the sides of the art piece on the wall, and cut miters in the cove moulding to fit around it. This can be done with a miter saw, miter box, or a 45° tablesaw sled.
Step 14: Attach the Moulding to the Wall
Use a finish nailer to attach the moulding to the wall around the edge of the art piece. I used a 16 gauge nailer, but 18 gauge will also work.
Step 15: Admire
It's done! Good job!
Also shown is a diffuser made in the same way, but with narrower pieces. I like the look of it, but it requires a lot more pieces when using narrower pieces.
Thanks for looking! Make sure to rate this project and follow me!
First Prize in the
Paint Challenge
21 Comments
2 years ago
Hi I love your project. Can you please tell me what kind of wood you used, not all wood shows so much character where you have made the crosscut, the endgrain in yours is very vibrant - and that's the part you see most. Thanks for letting me know.
Reply 2 years ago
Hello. All the wood I used was Douglas fir 4x4s. Those specific ones had some very nice growth rings.
Question 2 years ago on Step 7
You advise not to spread the glue so it catches the end grains better. Is this advice specific for glueing end grains? (I recently started spreading glue on every piece of wood because I saw many people doing that)
Answer 2 years ago
Yes, this is specific to gluing end grains on soft wood. On face grain I spread the glue thin with a brush.
For woodworking joints, the assumption is that end grain glue will have no strength, so the joints should be designed to have either a mechanical hold or face grain glue surfaces.
Reply 2 years ago
Clear. Thank you.
2 years ago
Looks like the one John Heisz made a few years ago. https://www.youtube.com/watch?v=nvx5NYpDt1k
Reply 2 years ago
Yes, it is very similar to that one.
2 years ago on Step 15
Good solid video and instruction. Very well thought out. Well worth my time to view and read. Have downloaded content. Thanks.
Reply 2 years ago
Thanks!
2 years ago
Good job for the material processing, but before you should know some adjustments according to the correction you should bring to your room characteristics, e.g. http://mh-audio.nl/Acoustics/DiffusorCalculator.asp
Reply 2 years ago
Ooh, that is really cool how it maps out all the pieces. Thanks for the link!
2 years ago
Nice!
But are the pieces cut to the sizes and glued in the order to officially required to achieve optimal acoustic benefit?
Thanx!
Gaston
Reply 2 years ago
They are not. The pieces would have to be much longer for the maximum acoustic benefit.
2 years ago
Very cool looking! How does this do with actual sound diffusing?
Reply 2 years ago
It definitely mellows out that wall a bit, but for the room to sound good, I also have foam in the corners and moving blankets hanging on two of the walls.
2 years ago
This is super cool. I would put this on my wall for sure.
Reply 2 years ago
Thanks!
2 years ago
Love it. I might need to make one.
Reply 2 years ago
Thanks!
2 years ago
This is great! I love the design :)
