Introduction: Sliced Banana Trick
How to do the sliced banana magic trick! Fool your friends and be the life of the party with this awesome magic trick! This video will show you how to cut a banana before you even peel it! All that you will need for this cool trick is a needle and a banana.
Step 1: What You Need...
You will need a banana and a sewing needle.
Step 2: Choose an Edge
Choose what edge of the banana that you would like to work with and poke a hole into it. Be careful that you don't poke the needle all the way through.
Step 3: Move the Needle and Cut the Banana
Move the pin back and forth inside the banana to actually cut the banana inside of the peel.
Step 4: Repeat the Process
Now just repeat this process and make your way down to the bottom of the banana.
Step 5: Flip the Banana
Now for the trick to work, you are going to have to flip the banana so the person peeling it cannot see the holes.
Step 6: Peel the Banana
Now you can remove the pin and peel the banana. After it's peeled you will have a pre-sliced banana and a cool trick to show your friends!
Step 7: Watch the Video!
Either click the embedded video or hit this link to see the video on how to do this trick! Sliced Banana Trick - YouTube
