Introduction: Sliding Plate
It's a skateboard. It's got two colors and a special pattern. It looks good.
Step 1: Manufacturing Edges
long13CM wide21CM
high1CM
*first place the paraboloid on the working plane and make it repeat.
*second expand the scale of repetition and lift it up, then change it into hole and original figure combination. (easy to make curved tips)
Step 2: Manufacture Intermediate
long55CM
wide21CM high1CM
*first place the cylinder on the working plane and repeat.
*second raise the repeating part and change it into the hole and the original figure.(a cylinder is easy to combine with a paraboloid)
Step 3: Combine and Trim
*first combine the
corner and the middle part so that they are 81CM in length
*second trim with two rounded corners(to make the combination of two smoother)
Step 4: Beautify
*first, cut the slide in half with the cube
*second, copy and put them together
*finally, turn color(make the board more beautiful)
Step 5: Manufacture Wheel
diameter5.5CM wide3CM
*First, cut the cylinder with two hemispheres
*second, combine it two rings and a cylinder
Step 6: Manufacturing Support
long7.5CM
wide5.5CM
*first, cut a cube with a cylindrical hole and combine it with a small cylinder(make the bracket more stable)
*second, one hemisphere is cut with a small hemisphere and transformed into a hole and bracket combination(make the shaft smoother)
*third, combine the assembly with two round edges and corners, a small cylinder and an arch(make bracket connection more natural)
*finally, cut two holes for decoration(beautiful)
Step 7: Beauty
Combine all part and add the pattern
Step 8: Finally
Accomplish!
