Introduction: Sliding Puzzle 'Next Move' Suggesting Simple DL Model With ESP32 TensorFlow Lite
This project takes the game Sliding Puzzle (with simple 'next move' suggesting 'search-directed heuristic' option), adding to it the capability of suggesting 'next move' with a simple and naive DL model realized with ESP32 TensorFow Lite support. The Sliding Puzzle game is implemented for Arduino framework compatible microcontroller boards with aids from DumbDisplay to render the game remotely on your Android mobile phone. Specifically, ESP32 / ESP32S3 is the targe microcontroller board for this experiment, since it not only supports Arduino framework, it also supports TensorFlow Lite.
Step 1: The DL Model
The DL model of this experiment is implemented with TensorFlow Lite that I worked out by referencing to two of my previous experiments:
- Trying Out TensorFlow Lite Hello World Model With ESP32 and DumbDisplay
- Mnist Dataset -- From Training to Running With ESP32 / ESP32S3
In addition to an ESP32 / ESP32S3 microcontroller board, a few tools are assumed:
- Python 3
- Git
- VSCode and PlatformIO -- reference on how they are used: A Way to Run Arduino Sketch With VSCode PlatformIO Directly
- DumbDisplay Android app -- reference: Blink Test With Virtual Display, DumbDisplay
Step 2: Building DL Model With VSCode
First, clone this project's source from the project's GitHub repository
Open the cloned directory ESP32SlidingPuzzle with VSCode, then open train_model.ipynb
Run all cells of the Jupyter Notebook train_model.ipynb.
- If environment is not setup already, it should first prompt you to create / select an Python environment.
- Create a virtual Python environment for the project
- As the last step, when asked to install dependencies, make sure to select requirement.txt
The DL model is naively constructed with Keras like
With accuracy 0.868, the DL model appears not very good, but should be acceptable
Step 3: Building and Uploading the Sketch
The steps to build and upload the sketch is via PlatformIO (an extension of VSCode).
The configurations for developing and building of the sketch are basically written down in the platformio.ini file
Notice that you have choices of PlatformIO environments -- ESP32 and ESP32S3
Please choose the correct one according to the microcontroller board that you have.
In either case, the program entry point is src/main.cpp
Notice that
- For ESP32S3, WiFi connection to DumbDisplay Android app is used. In such a case, you will need to provide necessary WiFi login credentials in a header file src/_secret.h that you need to create with content like
- Otherwise, for ESP32, Bluetooth connection to DumbDisplay Android app is used, with the Bluetooth device name ESP32Sliding
Build and upload the sketch with VSCode menu item View | Command Palette -- PlatformIO: Upload and Monitor
- For ESP32 which is using Bluetooth connectivity, you should see log entries with Serial Monitor (with baud rate 115200) like the second of the above screen shots
- For ESP32S3 which is using Wifi connectivity, the log entries will be like third of the above screen shots. Notice that the IP to connect to the ESP32 board shown by the log entries.
Step 4: Connect to DumbDisplay App
To connect your Android phone to your ESP32 / ESP32S3 microcontroller board via DumbDisplay Android app, open the DumbDisplay Android app and make connection like
Step 5: Sliding Puzzle Game UI
After connection, you should see the picture of the board drawn.
To start a game, double click on the board, to divide the board into grid of tiles
Double clicking on the board will randomize the board by 5 steps (5 random moves).
During game play, you can click Suggest for a suggested 'next move'. If you click Continuous, suggested 'next moves' are continuously made until either you disabled Continuous or the puzzle is solved.
There are three options for the 'next move' suggestion:
- AI Only -- use the trained DL model for predicting 'next move' (the highest probability one)
- AI+Search -- largely use the trained DL model for predicting 'next move'; however, if the top 'next move' probability is not high, fallback to use original "search* algo
- Search Only -- use original "search" algo only
After every solving of the puzzle, 5 more randomize steps are added to randomization making the game a bit harder.
Any time if you want to reset / restart the game, double click on the Reset button.
Step 6: Improving the 'Next Move' Suggestion Accuracy
The 'next move' suggestion is certainly not very accurate, specially when the board is randomized for many steps.
- The naive DL model can certainly be improved. Notice that intrain_model.ipynb, the training data is randomized in reverse of how a board is randomize. Hence, it makes sense that the number of randomize steps affects the accuracy of the model specially in case the game is randomized for more steps than the model is trained. Here are the parameters for training the model:
- round_count -- the number of rounds of random boards to generate; 10000 by default
- random_step_count -- the number of random moves from "solved orientation" to "randomized orientation"; 20 by default
- The "search" algo can be improved
- The DL + "search" can be improved
Moreover, the board size can be bigger, like 5x5. In order to change the board size to 5:
- Need to change tile_count of train_model.ipynb generate a sp_model_5.h for the sketch
- Need to modify the sketch esp32_sliding_puzzle.ino
- which controls
Interested friends are encouraged to try out and share how the 'next move' suggestion can be improved.
Step 7: A LLM Prompt for the Moves
BTW, here is a challenging LLM prompt for you to try out (just for fun)
From my experience, not all LLM models I tried can provide satisfactory response for the above prompt. One reason might be that the prompt is not well written; another might be that the answer to question 3 above can be "endless". GPT4o seems to provide reasonable response; but others like GPT4 or even DeepSeek might produce long response that appears never ending; hence, be prepared to stop the response generation.
Step 8: Enjoy!
Hope that you will have fun with it! Enjoy!
Peace be with you! May God bless you! Jesus loves you! Amazing Grace!
