Introduction: Sliding Wood Crate Storage
In this Instructable I'll show you how to make Sliding Wood Crate Storage. It's a perfect addition to any small or narrow closet to gain some extra space. And you don't need many tools to make it either!
Be sure to watch the video above, and if you like it please subscribe to my YouTube channel!
And if you think the project is cool I'd appreciate a vote up in the top right. Thanks!
Step 1: Gather Your Materials and Tools
Tools
Materials/Supplies
- (3) 18" Full Extension Drawer Slides
- (4) Large Wood Crates
- (1) Half Wood Crate
- (2) Small Wood Crates
- (2) 8' 1x4 pine furring strips
- Chalkboard Stickers
- 1-5/8 Wood Screws
- Wall Anchors
Affiliate links are provided for your convenience. Purchasing through these links helps support my site AT NO COST TO YOU and lets me share more projects and plans!
Step 2: Strengthen the Crates
I started by strengthening the crates. I pried the bottom slats away then put glue on them for added strength. I put an extra brad nail in each slat to help it stat put and dry.
Next i cut 2 18" pieces from a 1x4 for each crate. I screwed them to the top and bottom of the right sides of the crate with 1-5/8" screws.
Step 3: Paint the Crates (optional)
I painted the crates to give the closet some color. This trigger handle is an awesome addition to make spray cans perform better.
Step 4: Install Mounting Cleats
I cut 2 39-1/2" cleats from a 1x4 and mounted them in the closet.
I mounted the back one right in the corner with 2-1/2" screws. The front cleat went 18-1/2" from the back wall (to the front of cleat) and I attached it with wall anchors since I couldn't hit a stud.
Step 5: Mount Slides to Crates
I cut a space that was 6" by 18-1/2" and used it to mark the location for the slides on the crates. I drew a line on the top of the bottom of the spacer which gave me exactly parallel and spaced mounting lines.
I separated the slides and installed the extension piece on the crates using the lines to center the slides.
Step 6: Mount Slides to Wall
Using the same spacer I marked the position for the drawer slides on the cleats. This means the slides will be lined up exactly with the crate-side slide parts when I install them.
I spaced the second and third set of slides 6" below the slide above it.
Step 7: Install the Wood Crates
With all the slides mounted now I simply slide the crates into the mating slides on the wall.
I loaded them up and installed some labels on them for organization. It's worked out great and each crate can hold at least 20lbs. I did a weight test in the video if you'd like to see it here:
And if you want to see more great projects you can subscribe to my YouTube channel!
