Sling Shot Controller for Angry Birds
Intro: Sling Shot Controller for Angry Birds
Learn how to make a simple sling shot device to play Angry Birds using Arduino Leonardo. Below is the Arduino code with explanation in comments.
This code is in the public domain
Author: alpeshVitha
Date: 18th May 2013
int sPull = 0; // Start Position of the x axis
int ePull = 0; // End position of the x axis
int ysPull = 0; // Start Position of y axis
int yePull = 0; // End position of y axis
int range = 15;
int responseDelay = 1; // response delay of the mouse, in ms
// Declaration for smoothing the y axis reading. I found them very noisy, probably because potentiometer is logarithmic in nature.
const int numReadings = 10;
int readings[numReadings]; // the readings from the analog input
int index = 0; // the index of the current reading
int total = 0; // the running total
int average = 0; // the average
void setup() {
// initialize mouse control:
Mouse.begin();
Serial.begin(9600);
// Smoothing initialisation
for (int thisReading = 0; thisReading < numReadings; thisReading++)
readings[thisReading] = 0;
void loop() {
// read the initial state of sling at x axis and y axis
sPull = analogRead(A0); //x axis
ysPull = analogRead(A1); // y axis
ePull = sPull; // value of x stored in ePull variable
delay(100); // wait for 100ms for the finger to slide on the potentiometer
sPull = analogRead(A0); // read the x axis again
int pull = (ePull - sPull); // Delta x
// do the same for y axis to get Delta y
yePull = ysPull;
int ypull = (yePull - ysPull); // Delta y
if (sPull == 0){
if (Mouse.isPressed(MOUSE_LEFT)) {
Mouse.release(MOUSE_LEFT);
if(pull>-200){ // Adjust this value based on your set up
if(pull<200){// Adjust this value based on your set up
// calculate the movement distance
int xDistance = (pull/50)*range;
if (xDistance != 0) {
if (!Mouse.isPressed(MOUSE_LEFT)) {
Mouse.press(MOUSE_LEFT);
Mouse.move(-xDistance, 0, 0);
// Smoothing of Y
total= total - readings[index];
// read from the sensor:
readings[index] = ypull;
// add the reading to the total:
total= total + readings[index];
// advance to the next position in the array:
index = index + 1;
// if we're at the end of the array...
if (index >= numReadings)
// ...wrap around to the beginning:
index = 0;
// calculate the average:
average = total / numReadings;
delay(1);
int yDistance = (average)*2;
if (yDistance != 0) {
Mouse.move(0, -yDistance, 0);
// a delay so the mouse doesn't move too fast:
delay(responseDelay);
Author: alpeshVitha
Date: 18th May 2013
int range = 15;
void setup() {
Mouse.begin();
Serial.begin(9600);
void loop() {
yePull = ysPull;
if (sPull == 0){
// Smoothing of Y
index = index + 1;
index = 0;
delay(1);
3 Comments
azharz 10 years ago
azharz 10 years ago
Strontium 10 years ago
