Introduction: Slingshot
home-made slingshot (powerful but safe) - with this slingshot you can train your accuracy and shot (and knock down) some cans and buttles but it is not too powerful so you can also play safely with your friends! and most importantly its made by home waste only!!!
the supplies you need is:
- empty bottle
- rubber band
- used (or unused) balloon
- scissors
- small rock
Step 1:
for this step all you need is the bottle and the scissors.
cut the bottle about an inch below the cap.
you gonna use the part with the cap (the smaller part)
Step 2:
in this step you going to cut the balloon.
for this you need the balloon and the scissors.
cut the balloon around it top part and make sure to make it wide enough so it can go around the bottle's "neck"(cap).
Step 3:
in this step you finally gonna have the slingshot itself (but you are not done!).
you gonna need the top part of the bottle you just cut in step one, the rubber band and the piece of the balloon.
use the rubber to attach the balloon to the smaller part of the bottle instead of the cap (make sure you took the cap off first and put the cap in the bigger part of the bottle).
Step 4:
make sure to recycle the balloon and the bottle (with the cap in it)
Step 5:
put the small rock you just found in your garden inside the bottle all the way down to the balloon.
Step 6:
start practicing by stretching the rock inside the balloon, aim and shot!
