Introduction: Small 6 Volt Safe
In this instructable i will show you how to make a hidden safe out of a small 6 volt battery. it is smaller, but looks better than my other battery safe.
Step 1: Step 1: Get Your Supplies
What you need:
Standard size 6 volt lantern battery
Knife
Wire cutters
Box
Gloves
Source of water
Knife
Wire cutters
Box
Gloves
Source of water
Step 2: Step 2: Start Scoring
Start by scoring the edges of the battery around the top with the knife to remove the glue.
Step 3: Step 3: Give It a Wack!
After scoring the battery, lightly smash itt against a table. Do this care fully so as not to crack the casing or the clips in the top of the cover.
Step 4: Step 4: Cut
Now cut the wires that are connected to the battery top.
Step 5: Step 5: Empty
Empty the battery contents into a box.
Step 6: Step 6: Cut
Now you should have a cross like piece of plastic attached to the sides. cut this out carefully. Make sure to be careful at the sides, it is easy to break the plastic. After it is done you should have something like in the second picture.
Step 7: Step 7 : Rinse
Now rinse out the battery for about 2 minutes.
Step 8: Step 8: Finish
Now you can put whatever you want into it, and put the cover back on, it shuld look normal.
Step 9: Step 9: Options
Now you can customize it. If you want to, add a holder for 4 AA batteries, and solder it to the terminals ( negative to negative, positive to positive ) so you can show it's "real". You could also modify the ciruit i used in my casset player safe mod, so when it opened a buzzer and/or lights would go off.
Step 10: Video
This is a video of the hidden safe, with some bonus content :) !
I also made a mistake, at the end i call it a 9 volt safe, it should be a 6 volt safe. Whoops!
Step 11: Thanks
Thank you for reading my instructable, please look at my other ones. feel free to leave any comments or suggestions... blah blah blah ...they are appreciated
