Introduction: Small Backyard Garden Space
This is Small Backyard Garden Space you will use as decoration piece.
This is a small setup of actual-size flower garden and small garden house for conserving and growing essential flowers, vegetables and berries inside a backyard space.
Its like small diorama of actual big garden.
Lets gather below things and we are ready to make it happen.
Things needed:
1. Ice cream sticks. x 150 Pieces
2. Transparent plastic sheets.
3. Scissors and paper cutter
4. Instant adhesive
5. Modeling clay
6. Some water color for painting
7. Normal clay for pot filling
8. Acrylic spray paint (only for backyard house painting)
9. Real small flowers and plans for garden decoration
Instead actual flowers you will use plastic flowers and plants.
Step 1: Rack for Pot Placement
Now we make rack for pot placement
1. Take 8 sticks of ice-cream sticks.
2. cut round edge and make it flat , now it shows rectangle sticks.
3. connect 2 piece of stick side by side to make it combine.
4. take 2 pieces of stick and place it apart and place 2 combined stick on 60mm to make rack and use instant adhesive to make it rigid.
5. use another 2 single ticks to place mirror side of sticks and join them.
6. Now your first rack is ready, make another rack same as 1st.
Step 2: Table for Pot Placement.
1.Take 6 sticks.
2. cut curved parts for make rectangle sticks.
3. cut 2 sticks in half and make 4 half piece.
4. Connect 4 full sticks side by side to make table top.
5. Connect 4 other half sicks on corner of table top as legs.
Step 3: Base of Backyard Garden House
Take 41 Sticks for base.
Part-1
1. take 7 sticks, cut curved parts of them to make them rectangle.
2. take 1 stick and make it half.
3. take another stick to make multiple part of 10mm cutting parts.
4. take full and half stick and connect 10 mm piece on top of that to make it longer.
5. Revise another time to make 2nd long stick by connecting 2 of them.
Part-2
6. take 22 full stick with one side curved surface cut and take 22 half stick without cut curved part.
7. take 22 full sick side by side and connect them by placing on shorter edge and connect them using adhesive .
8. do them for half sticks and use 2 sticks to connect them on shorter edge.
9. take another 2 full sticks and connect flat edges of above 2 connected parts.
Now you got whole Base .
10, make above part-1 sticks to connect them around base horizontally and place inside to connect using adhesive.
Step 4: Make Corner Pillars.
1. take 15 sticks.
2. cut one side of curved edges of 10 sticks.
3. cut other 5 sticks in half.
4.connect 1 full and 1 half sicks connect .
5. use 2 of them to connect 90* angle to make 4 pilers.
6.Stick this 4 90* angle pillars on each side of base.
7. The other 2 straight sticks on the center.
So, this pillers are connected vertically to base
Step 5: Make Beam Structure
1. take 9 sticks.
2. cut 8 sticks curved part fron one side.
3. cut 9 th stick in half.
4. Connect 6 full stick.
5. connect 2 half and full sticks.
6. Connect long sticks in along side of pillar(all four side).
7. connect short 2 stick at center places.
Step 6: Roof Construction
Take 23 full stick. cut 3 half and connect them on top of each other.
1. make 3 double stick join side by side
2. place use 4 sticks to connect them by certain distance(distance between couple of 3 stick is 80mm)
3. make another same .
4. connect 3 half connected stick on vertical to center beam for support roof part.
5. Place 2 identical roof on side by side of vertical sticks and join them to completer roof shape and structure.
connect roof and base structure to make single structure of backyard garden.
Step 7: Door Construction
Part-1
- Take 4 stick. cut all round corners
- cut 1 stick in half
- Cut one stick in half by longer edge.
- For make door connect 2 full and half stick to make rectangle shape and connect them
- use half stick cut on longer edge to connect on side of door to make a hinge.
Part -2
- Take 3 stick.
- cut 1 stick in half.
- connect 2 full stick to half sticks separately. make center hole to 2 full sticks for make hinge point.
- Connect them and placement of this 2 holed sticks on place of door and consider both hole at the left side to make hinge.
- connect door by placing vertical half stick into hole.
- If needed use 45 degree cut for proper fitment.
For more rigidity of structure.
- Take 3 stick, connect 2 full stick and 2 half sticks separately.
- Connect them inside structure just behind the door position.
Step 8: Small Garden Box
- Take 10 stick.
- connect 4 stick side by side to make base.
- connect 2 pair of 2 -2 sticks .
- Cut 2 stick in half and make 2 pairs of 2-2 stick, side by side connected.
- connect this sticks on side of base to make closed box.
Step 9: Pot Making
- Use modeling clay to make Pots.
- combine 2 parts of modeling clay.
- Make if flat sheet approx. 4 mm thick.
- cut 15 mm circular parts from this flat as needed to make pot bottom.
- make another flat for make rectangle , behave as side profile of pot.
- Connect bottom and side profile to make pot.
- This take some time to solidify.
- Make as much pot as you like.
- Use paint to color the pots as you like.
Step 10: Color of Backyard House
- Use spray acrylic color to paint structure of backyard house.
- I use yellow color to paint.
- Use plastic sheet to cover the structure from outside.
- take measurement as per your structure model and cut using scissors.
- use adhesive to joint plastic sheet on structure.
Step 11: Filling and Placement of Pots.
- Use normal wet soil to place inside pot and small garden pot.
- use actual or plastic flowers and plant to place inside pot.
- arrange rack and table inside Backyard house and place pots on rack and table .place Small garden box outside Backyard house.
- If you want to make it more realistic, use 2ftx2ft board .
- Place soil layer inside.
- use some stick to make path to go inside Backyard house.
- Use some plastic statues around it.
Step 12: Final Results
Now your small Backyard house garden is ready to grow vegetables, flower and berries.
Enjoy.
