Introduction: Small Lego Birds
I made two lego birds sitting on branches but on a way smaller scale!
Bird 1:
  • One Lego Bright Light Orange Slope, 1 x 1
  • One White Lego Plate, Modified 1 x 1 with Tooth Horizontal
  • One Lego Dark Gray Lego brick, with studs on two sides, 1 x 1
  • Two Lego Yellow Slopes, 1 x 1
  • One Black Lego Plate, 1 x 1
Bird 2:
  • One Dark Gray Lego brick, 1 x 1
  • Two Lego White Slopes, with studs on all sides, 1 x 1
  • One Lego White Tile, 1 x 1
  • One Lego White Tile, 1 x 1, Quarter Round
Tree:
  • Two Brown Lego Plates, Modified 1 x 4 with 2 Studs
  • One Brown Lego Plate, 1 x 2
  • Two Brown Lego Brick, 1 x 2 log
Step 1: Build Bird #1
  1. Take One Lego Bright Light Orange Slope, 1 x 1, and stack it on top of your One White Lego Plate, Modified 1 x 1 with Tooth Horizontal.
  2. Then stack that on top of your Lego Dark Gray Lego brick, with studs on two sides, 1 x 1. Make sure that the two studs are facing the sides.
  3. Attach a Black Lego Plate, 1 x 1 to the bottom of that. Then rotate the black plate at around a 45 degree angle!
  4. Attach Two Lego Yellow Slopes, 1x1 to the side of the Lego Dark Gray Lego brick, with studs on two sides, 1 x 1 at an angle so that the slope is facing slightly down!
Step 2: Building Bird #2
  2. Then stack that on top of your Lego White brick, with studs on all sides, 1 x 1.
  4. Attach Two Lego White Slopes, 1x1 to the side of the Lego White brick, with studs on two sides, 1 x 1 at an angle so that the slope is facing slightly down! (See Pictures)
  5. Finally, attach one Lego White Tile, 1 x 1 to the opposite side of the tooth, and attach a Lego White Tile, 1 x 1, Quarter Round to the opposite side of the tile you just placed!
Step 3: Building the Tree
  1. Take one Brown Lego Plate, Modified 1 x 4 with 2 Studs, and place it on top of a Brown Lego Brick, 1 x 2 log.
  2. Underneath the Brown Lego Brick, 1 x 2 log you just used, place another Brown Lego Plate, Modified 1 x 4 with 2 Studs on the right side. On the left side, place a Brown Lego Plate, 1 x 2.
  3. Finally, on the very bottom of the build, put another Brown Lego Brick, 1 x 2 log underneath the build. Make sure to align it with the other log brick!
Step 4: Finished
Attach the two birds to the tree however you would like to and "Voila", your done!
