Introduction: Small Parts Storage Boxes From Scrap Wood
I used to store screws, bolts and similar small materials in my workshop in plastic boxes or in their original cardboard boxes.
I wanted to make wooden boxes in order to be more useful and look more beautiful. I've looked at many examples on the internet. Then I made my own design. I designed boxes in suitable sizes for my workbench, which I made from used wood.
While designing these boxes, I used pieces of thermowood paneling that could be thrown away or burned.
I made 20 boxes in total. I joined the boxes with my favorite finger joint method.
As a result, it was a project that I really enjoyed doing and liked very much. I have also evaluated many old wooden materials.
I hope you like it.
- Lots of scrap woods (thermowood 20mm thickness)
- Scrap plywood 8mm
- Nail puller
- Hammer
- Circular saw which is mounted on the table
- Hand router and router bits
- Sand papers (various)
- Teak oil
- Screws
- Drill press
- Clamps etc.
Step 1: Removing Nails
I carefully cleaned all nails and foreign material.
Step 2: Separation and Sizing
I rip cut all the woods to be 85mm wide. Then cut them exact length which is 200mm and 150mm.
Let's go to the next step.
Step 3: Choosing Wood Joints
I'm trying to some alternatives for joinery, especially finger joints.
I decided on the 12.7mm (1/2") one which that is strong and looks great.
Rabbets cut with 8mm bit on the bottom sides for box bases.
Step 4: Gluing and Sanding
Let's make some sanding... Before assembly, I sand the interior surfaces.
Then gluing all together and let it dry all night.
Step 5: Wood Finishing With Teak Oil
I'm using teak oil to finishing this boxes. By the way added box bases too.
Step 6: Making Cabinet for Boxes
I used the same scrap wood for the cabinet and also used scrap plywood.
I glued two pieces together to get a wide piece.
Step 7: And the Final Step
Firstly I make fillets on all sides against breakage.
Then placing cabinets on the workbench. I drilled large holes in the boxes as handles.
And I finaly filled the boxes with hardwares.
