Introduction: Small Strobe Light
Runs for over 2 hrs from a 9V battery, fits into a altoids gum tin.
A fun project that cost under $50 and takes under 2 hours.
you also get to claim bonus geek points when your electronics come with a warning like:
"WARNING! Luxeon LEDs are extremely bright! Looking directly into a into a lighted LED will cause eye damage! Use caution when working with these LEDs"
Step 1: Components
The components I used:
Luxeon V star. The most powerful led available!
LED Dynamics Buck Puck, p/n 03021-D-I-1000 1A Wide range high output LED driver module
lm555 timer ic
8 pin socket for 555 ic
47µF 16V electrolytic capacitor
270 ohm variable resistor
270 ohm 1/4 watt carbon resistor (red purple brown)
9V battery snap
jumper wires
proto board with copper solder pads around each hole
heat sink from an old motherboard
two tiny nuts and bolts
Altoids gum tin
Tools:
Soldering iron w/ solder
diagonal cutters
utility knife (to cut proto board)
drill with bit same diameter as your tiny bolts
Step 2: Build 555 Astable Multivibrator Circuit
I recommend breadboarding the entire circuit first. It was way easier on a breadboard that trying to figure out what goes where on a tiny piece of protoboard.
Start by building the 555 astable multivibrator circuit. I used a 270 ohm fixed resistor between pin 7 and Vcc and a 270 ohm variable resistor between pins 6 and 7
This circuit uses an RC time constant (see: http://en.wikipedia.org/wiki/RC_time_constant.) By changing the resistance between pins 6 and 7 or the size of the capacitor, you can control the rate of the strobe.
For the variable resistor, I used what I had handy. A 1K ohm variable will give you a greater strobe range.
Step 3: Interface the Timer to the LED Driver
Next, interface your 555 timer circuit to the Buck Puck LED driver. This is easy. Just put a jumper wire from pin 3 of the 555 to the control pin of the Buck Puck.
I would wait to attach the Luxeon V to the driver yet. If you power it up, and it's not heatsinked, it can go into thermal runaway and melt itself down.
Note that the ref pin is not used.
Step 4: Prepare the Case (altoids Tin)
Next I drilled a couple of holes in my heatsink, and through the altoids tin and bolted the Luxeon star to the heatsink and to the lid of the tin.
Run the wires from the LED to the + and - on the Buck Puck, double check your circuit, and test it out!
Don't forget to snip a little hole in the side for the wires to come out.
Step 5: Put It in the Can
After you get the circuit working on a breadboard, transfer it over to a proto board. I used a dimension of 12x12 holes, with the corners rounded off to fit snug in the case. There is just enough room to fit the 9V in below it. That's it! Remember not to stare at it, or you'll go blind!
as an optional upgrade, I'm going to mount a microswitch in alongside the battery, and wire it in series so that when the lid is closed, the strobe comes on, and when you open it, it turns off.
Obviously there are more ways to skin this cat. I have been thinking about using several Luxeon III's spread out over a larger area to give a more dramatic effect. BTW, this was great inside my pumpkin.
39 Comments
11 years ago on Introduction
My question is if you can simply bypass the 555 circuit with a 2-way switch to have a steady on option? flip one way to strobe and the other for steady on?
i want to make a cheap led strobe kit. i want the lights to be bright but i just cant figure out how to make the circuit work. can some one help? please
can i use the simple led driver as seen the led driver instructable which consists the LM 317 voltage regulator coz i am unable to obtain the led driver buckpuck. have u any replacement or alternative for that device????
12 years ago on Step 5
Why is the LED Driver Puck Buck for? Is it needed?
Reply 11 years ago on Introduction
It regulates the power to the LED, without it the LED would burn out pretty quickly. The 555 circuit is to make the LED flash.
12 years ago on Step 3
By heatsinked are you referring to the Buck Puck LED Driver or the Luxeon V?
The driver is connected to the altoids case, which acts as a heatsink, so he means the led itself.
im at a loss here. Alot of steps seemed to have been skimmed over or skipped completely.
It's not that it's incomplete, it's simply not very detailed. For example, one of the steps is "Build a 555 astable multivibrator circuit". Also, the steps are somewhat self contained, just showing an electronics schematic, and trusting you to figure it out from there. It does require some prior electronics experience, and is not a beginner project.
12 years ago on Introduction
How much do each of the parts cost, and is there a good website to order them?
is there a reason why you did not take advantage of the 5V REF supply integrated into the buckpuck?
Was it because of the current threshold being too low to adequately feed the 555?
Would the LMC555 work better due to lower current consumption?
13 years ago on Step 2
yes.... with the 330 Ohm resistor the led will not draw much current or be too bright and the 555 is protected from overload....in step 2 the 555 is connected to the driver with no resistor and the driver feeds the led with no resistor needed...but if you don't remove the original resistor and led no damage will occur...
13 years ago on Step 1
nice project but....not 'the most powerful led available' , 100w leds have been around for quite awhile ( search ebay...'led 100w')....and now in many colours
13 years ago on Introduction
i think your 555 schematic in the instructable is fudged up. it shows a diode, not on the parts list, a 4.7K resistor (wasn't that supposed to be a cap?) and the value for your pot is marked incorrectly (100K or 1K?). I'm bailing on your schematic, and trying toddj's next.
The buck puck has a maximum strobe rate of 50us. if i wanted to use this for stop motion video, and trigger it off of sensor how would i advance / delay the ttl pulse for fine adjustment? Thanks!
Reply 13 years ago on Introduction
Like this?
I want to build this circuit but there are a couple of things I don't see explained on the schematics. In step 2 the completed 555 astable circuit shows an LED connected between pin 3 and pin 5 etc. of the 555 IC. What happens to this LED when the astable circuit is connected to the Buck Puck? Is it eliminated along with the 330 Ohm resistor? Thanks, Ed65
14 years ago on Introduction
what if lds are connected directly to the battery?
depending on the kind they would either shine bright or burn out.....
And, is the control pin kinda like the base on a transistor, a sort of switch?
