Introduction: Small Trebuchet
This Trebuchet instructable is for someone looking to have some fun with a project or needs instructions for how to build one for school. Some provisions made need to be made with your trebuchet to make it work the best so testing it around wont hurt. Setting up the trebuchet like the one provided should give consistent results from 15-25 feet of being capable to launch. This project does take quite a bit of time but if you have the time for it, it will definitely pay out.
Step 1: Materials
  1. 4 eye hooks
  2. screws and nails (any kind)
  3. hammer
  4. 2 2x4s 18 inches long and 2 2x4s that are 6 inches long
  5. wheels
  6. Spray Paint (Optional)
  7. 2 2x4s that are 11.5 inches and 1 2x4 that is 20 inches long (Swing Arm)
  8. piece of plywood that is 10x10 inches and is cut in half
  9. piece of cloth
  10. piece of metal that is 7.5 inches long and 1 inch thick
  11. piece of plywood that is 18 inches long and 6 inches wide
  12. string
  13. drill
  14. weights
  15. Zip Ties
  16. Saw
Step 2: Step 1
Take 1 2x4 that is 18 inches long and 1 2x4 that is 6 inches long and nail them together
Step 3: Step 2
repeat step one and drill the two pieces together so that a base is formed for the trebuchet
Step 4: Step 3
take the piece of plywood that is 10x10 inches long and cut it in half so the two pieces are 5x5 inches long
Step 5: Step 4
cut a hole directly into the two pieces of wood that are 11.5 inches long and make sure that they are perfectly alligned
Step 6: Step 5
measure 6.5 inches from one side of the base and apply an 11.5 inch piece to the base so it serves as an upright for the swinging arm
Step 7: Step 6
repeat step 5 to the other side of the base so that two 11.5 inch pieces are lined up equally and each has a hole for the metal to go through
Step 8: Step 7
place the piece of metal that is 7.5 inches long and 1 inch thick into the two holes so that it is able to hold up the swinging arm (Make sure the arm can move freely around the metal so the trebuchet can obtain its maximum throwing range)
Step 9: Step 8
attach the swinging arm to the piece of metal by cutting a hole 5 inches from one side of the swinging arm and make sure the metal can fit through the hole. Cut another hole 1.5 inches from the same side you just cut your whole in so the zip ties can hold the weights
Step 10: Step 9
take the two pieces of plywood you cut in step three and attach them to the outside of the supports to cover up any nails and give the base more strength
Step 11: Step 10
take the big piece of plywood that is 18 inches long and 6 inches wide and stick it in between the two supports attached to the base, then nail it in place
Step 12: Step 11
take 2 eyehooks and screw them into the plywood that is attached to the base (1 inch from each side of the plywood is where you should screw)
Step 13: Step 12
cut a piece of cloth that is 5 inches by 3 inches to act as a slot to launch the golf ball
Step 14: Step 13
take two more eyehooks that are spaced two inches from each other on the bottom of the short piece of the swing arm and attach them
Step 15: Step 14
Take a nail and remove its head with a metal cutter, attach it to the end of the swing arm and slant it up the loop you are about to create can release and launch
Step 16: Step 15
tie knots around the 2nd eyehook of the swing arm that is attached to one end of the cloth
Step 17: Step 16
on the other side of the cloth, attach a string that is 10 inches long and tie a loop on the end to connect it to the nail
Step 18: Step 17
take a zip tie and put it through the hole that is 1.5 inches away from the short side of the swing arm and attach a weight (preferably 10-15 pounds)
Step 19: Step 18
once the weights are attached, make sure you create a trigger that can hold down the swing arm and release when the string is pulled
Step 20: Step 19
spray paint your piece if you want to
Step 21: Step 20
After you have finished all of these steps, give a pat on your back and go test it out to see if you need to fix any error
Step 22: Final Step
You have finished your trebuchet! Have Fun with it!!!!!
