Introduction: Small and Simple Wifi NTP Clock
Your own physical clock always on time because syncronized on NTP server through your Wifi (same as computers and smartphones).
After some searches I choose these components :
ESP32-C3 super mini because it is simple, cheap and has embeded wifi
TM1637 display 0.56 inch the biggest size of 4 x 7 segments I found for clock display
Level shifter with BSS138 because you need to convert 3.3V to 5V in two ways
10 µF capacitor (black cylinder) for stability on current peaks
100 nF capacitor (brown with 104 marking) for interference filtering
Wires
Step 1: Wire Components
Wire components according to this schema on a breadboard to test or directly soldering wires and capacitors.
I tested it on a breadboard without soldering headers but it was a little bit tricky to have contacts everywhere at the same time :).
Take care about the polarity of black capacitor.
Step 2: Upload the Code on ESP32-C3 Super Mini
To set and upload the code on ESP32 card I used VS code with PIO Home plugin and the following configuration for platformio.ini file. Don't forget to update your upload port.
; PlatformIO Project Configuration File
; Build options: build flags, source filter
; Upload options: custom upload port, speed and extra flags
; Library options: dependencies, extra library storages
; Advanced options: extra scripting
; Please visit documentation for the other options and examples
; https://docs.platformio.org/page/projectconf.html
[env:adafruit_qtpy_esp32c3]
platform = espressif32
board = adafruit_qtpy_esp32c3
framework = arduino
lib_deps = https://github.com/avishorp/TM1637.git
upload_port = /dev/cu.usbmodem1101
Below is the C++ code I used.
You have to set you Wifi SSID and password, the ntp server and the time zone (here configured for Europe/Paris).
You can also set the brightness, and choose flashing or constant colon.
Notice there is a lot of serial outputs for debugg, you can remove them for the final version.
main.cpp file
#include <WiFi.h>
#include <TM1637Display.h>
#include "time.h"
// --- Set here ---
const char* ssid = "yourssid";
const char* password = "yourpassword";
// Choose output pin
#define CLK_PIN 2
#define DIO_PIN 3
TM1637Display display(CLK_PIN, DIO_PIN);
// Time zone and DST rules for Europe/Paris
// "CET-1CEST,M3.5.0/02:00:00,M10.5.0/03:00:00"
const char* ntpServer = "ntpserver";
const char* tzString = "CET-1CEST,M3.5.0/02:00:00,M10.5.0/03:00:00";
void printLocalTime(){
struct tm timeinfo;
if(!getLocalTime(&timeinfo)){
Serial.println("Error on getLocalTime");
return;
char buf[64];
strftime(buf, sizeof(buf), "%Y-%m-%d %H:%M:%S", &timeinfo);
Serial.println(buf);
// Animation function for init - Display moving segment
void animateSegment(uint8_t segment) {
uint8_t seg1[] = {segment, 0, 0, 0};
uint8_t seg2[] = {0, segment, 0, 0};
uint8_t seg3[] = {0, 0, segment, 0};
uint8_t seg4[] = {0, 0, 0, segment};
static int animCount = 0;
animCount++;
if (animCount % 4 == 1) {
display.setSegments(seg1);
} else if (animCount % 4 == 2) {
display.setSegments(seg2);
} else if (animCount % 4 == 3) {
display.setSegments(seg3);
} else {
display.setSegments(seg4);
void setup() {
Serial.begin(115200);
delay(1000);
Serial.println("Début setup");
display.setBrightness(0x0f); // 0x00..0x0f : brightness mini to maxi
display.clear();
// WiFi Connection
Serial.print("WiFi Connection");
Serial.print(ssid);
WiFi.begin(ssid, password);
unsigned long start = millis();
int dotCount = 0;
while (WiFi.status() != WL_CONNECTED) {
delay(250);
Serial.print('.');
dotCount++;
// Animation during Wifi connection
animateSegment(SEG_D);
if (millis() - start > 15000) { // timeout 15s
Serial.println("\nImpossible to connect to WiFi");
break;
Serial.println();
Serial.print("WiFi status: ");
if (WiFi.status() == WL_CONNECTED) {
Serial.println("OK");
// Display 200 when WiFi is connected
display.showNumberDecEx(200, 0, false, 4, 0);
} else {
Serial.println("KO");
// Display 500 when WiFi cannot connect
display.showNumberDecEx(500, 0, false, 4, 0);
delay(3000); // 3 seconds delay for error message
Serial.println("Impossible to connect to Wifi - Reboot...");
display.clear();
Serial.flush();
// NTP and timezone configuration
struct tm timeinfo;
int ntpAttempts = 0;
const int MAX_NTP_ATTEMPTS = 3;
bool ntpSuccess = false;
// NTP configuration, one time
configTzTime(tzString, ntpServer);
while (ntpAttempts < MAX_NTP_ATTEMPTS && !ntpSuccess) {
ntpAttempts++;
Serial.print("Looking for NTP server (try ");
Serial.print(ntpAttempts);
Serial.print("/");
Serial.print(MAX_NTP_ATTEMPTS);
Serial.println(") ");
// Animation during NTP synchronization (timeout 10s)
unsigned long ntpStart = millis();
int ntpDotCount = 0;
while (!getLocalTime(&timeinfo) && (millis() - ntpStart < 10000)) {
delay(250);
Serial.print('.');
ntpDotCount++;
animateSegment(SEG_G);
Serial.println();
if (getLocalTime(&timeinfo)) {
ntpSuccess = true;
Serial.println("NTP server OK !");
printLocalTime();
} else {
if (ntpAttempts < MAX_NTP_ATTEMPTS) {
Serial.println("NTP attempt failure, retry...");
delay(2000); // 2 seconds wait before retry
if (!ntpSuccess) {
Serial.println("NTP server does not respond after 3 retries.");
unsigned long prevSec = 0;
bool colonOn = true;
void loop() {
struct tm timeinfo;
// si pas d'heure, afficher "----"
uint8_t segNoTime[] = {SEG_G, SEG_G, SEG_G, SEG_G};
display.setSegments(segNoTime);
delay(1000);
return;
printLocalTime();
int h = timeinfo.tm_hour;
int m = timeinfo.tm_min;
int toDisplay = h * 100 + m;
// If you want colon flashing every second
// unsigned long now = millis();
// if (now - prevSec >= 500) { // toggle 0.5s for flashing
// colonOn = !colonOn;
// prevSec = now;
// Or keep colon on all the time
uint8_t colonMask = colonOn ? 0b01000000 : 0;
display.showNumberDecEx(toDisplay, colonMask, true, 4, 0);
// Update every 200 ms
delay(200);
Step 3: Print the Body
Here are the 2 parts of the body, the main body and the back cover.
The back cover has the USB-C connector and support the ESP32 card. This part needs sometime adjustments due to small shape differences on ESP32 and USB C connector position.
Step 4: Assemble Evrything
Put the display in the main body and ESP32 on the USB C hole of the back cover.
There is some pin holes to attach them or you can use hot glue.
Then you can close the back cover (easy to open).
Plug the device on USB C and wait for initialisation on Wifi and NTP server.
Enjoy this always on time clock.
