Introduction: Smart Buoy - [Making Wave and Temperature Measurements]
This Smart Buoy series charts our (ambitious) attempt to build a scientific buoy that can take meaningful measurements about the sea using off-the-shelf products. This is tutorial one of four. If you need a swift introduction to the project, check out our summary.
In this tutorial, we show you how we took wave and temperature measurements on our Smart Buoy.
Step 1: GY-86: Accelerometer & Gyroscope
The main sensor on the buoy is a GY-86, which contains the MPU6050 accelerometer gyroscope, the HMC5883L Magnetometer and the MS5611 barometer. These sensors enable us to measure air temperature, wave height, wave period and wave energy (and wave direction if someone out there is smart enough to do the maths).
The GY-86 communicates via i2C - see the schematic. This is the code we used to access the accelerometer and gyroscope readings.
#include "Wire.h"
#include "I2Cdev.h"
#include "MPU6050.h"
MPU6050 mpu;
int16_t ax, ay, az;
int16_t gx, gy, gz;
void setup() {
Serial.begin(115200);
Wire.begin();
Serial.println("Initializing MP6050...");
mpu.initialize();
Serial.println(mpu.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");}
void loop() {
mpu.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
printResults();
delay(10);
void printResults(){
Serial.print("Acc (x,y,z) m/s/s: ");
Serial.print(ax); Serial.print(" ");
Serial.print(ay); Serial.print(" ");
Serial.print(az);
Serial.print(" Gyro(x,y,z) °/s: ");
Serial.print(gx); Serial.print(" ");
Serial.print(gy); Serial.print(" ");
Serial.println(gz);
}Attachments
Step 2: GY-86: Magnetometer (Compass)
The GY-86 contains a magnetometer which we use as a compass. You don’t need to change any connections - woo! Here’s the code to get the compass value
Remember to use the value of declination specific for your location otherwise your results may be inaccurate.
#include "Wire.h"
#include "I2Cdev.h"
#include "HMC5883L.h"
MPU6050 mpu;
HMC5883L mag;
int16_t mx, my, mz;
// Find the declination where you are from http://www.magnetic-declination.com
// -14° 59'
float declination = (-14.0 - (59.0 / 60.0)) * (PI/180);
void setup() {
Wire.begin();
Serial.println("Initializing I2C devices...");
mpu.setI2CMasterModeEnabled(false);
mpu.setI2CBypassEnabled(true) ;
mpu.setSleepEnabled(false);
mpu.initialize();
mag.initialize();
Serial.println(mag.testConnection() ? "HMC5883L connection successful" : "HMC5883L connection failed");
void loop() {
mag.getHeading(&mx, &my, &mz);
printResults();
delay(200);
float heading = atan2(my, mx);
heading += declination;
if (heading < 0) heading += 2 * PI;
if (heading > 2 * PI) heading -= 2 * PI;
heading *= 180/M_PI;
Serial.print("Heading °:");
Serial.println(heading);
}Attachments
Step 3: GY-86: Barometer and Temperature
Here’s how we got the values from the MS5611 barometer.
#include "Wire.h"
#include "I2Cdev.h"
#include <ms5611.h>
MPU6050 mpu;
MS5611 baro;
double temp;
long pressure;
double altitude;
void setup() {
Wire.begin();
mpu.initialize();
while (!baro.begin(MS5611_ULTRA_HIGH_RES)) {
Serial.println("MS5611 connection unsuccessful, check wiring!");
delay(500);
void loop() {
temp = baro.readTemperature(true);
pressure = baro.readPressure(true);
altitude = baro.getAltitude(pressure);
printResults();
delay(200);
Serial.print("Pressure hPa: "); Serial.print(pressure);
Serial.print(" Altitude m: "); Serial.print(altitude);
float tempC = temp / 340.00 + 36.53;
Serial.print(" Temp °C: "); Serial.println(tempC);
}Attachments
Step 4: Crude Wave Height
Once all those sensors are set up, you can use them to start measuring wave properties.
Starting with wave height...the altitude of the buoy can be calculated using the air pressure value. We can use the relative altitude of the buoy over a time period to work out the wave height like this:
#include "Wire.h"
#include "I2Cdev.h"
#include "MPU6050.h" // ^
#include <ms5611.h> //
MPU6050 mpu;
MS5611 baro;
long pressure;
double altitude, min_height, max_height, wave_height;
void setup() {
Wire.begin();
mpu.initialize();
delay(500);
void loop() {
unsigned long start_time = millis();
max_height = altitude;
min_height = altitude;
// for 15 seconds
while(millis() - start_time < 15000){
if (altitude < min_height) min_height = altitude;
if (altitude > max_height) max_height = altitude;
wave_height = (max_height - min_height)/2.0;
Serial.print("Wave Height m: ");
Serial.println(wave_height);
}Attachments
Step 5: Crude Wave Period
The next thing is wave period. We used airy wave theory - a lovely basic wave theory which says that water surface waves can be described as sine waves. It’s great to use because it makes the maths easier, but it is of course a simplification and does have certain caveats, including that it is inaccurate in shallower water where waves transform and break. Using this theory, we should be able to get a value of wave period using the midpoint between our maximum and minimum relative altitudes and finding how frequently the buoy crosses this point.
#include "Wire.h"
#include "I2Cdev.h"
#include <ms5611.h>
MPU6050 mpu;
MS5611 baro;
long pressure;
double altitude, min_height, max_height, mid_point, smudge_factor;
byte escaped, started;
unsigned long period_start, period_end;
float avg_period = -1;
void setup() {
Wire.begin();
mpu.initialize();
delay(500);
void loop() {
// for 15 seconds
mid_point = (max_height + min_height)/2.0;
smudge_factor = (max_height - mid_point)*0.15;
Serial.print("Mid Point m: "); Serial.print(mid_point);
// for 15 seconds
// if within a range of 30% of wave height from the mid point
// start the timer else stop it
if (altitude < mid_point + smudge_factor && altitude > mid_point - smudge_factor){
if ( !started){
period_start = millis();
started = true;
else{
if ( escaped ){
// if it has started and escaped and is now returning
period_end = millis();
started = false;
escaped = false;
// if the variable has already been assigned
// use its previous value and new value to work out avg
if(avg_period != -1){
avg_period = (avg_period + (period_end-period_start)*2) / 2.0;
// assign it
else{
avg_period = (period_end-period_start)*2;
else{
escaped = true;
Serial.print(" Period s: "); Serial.println(avg_period/1000);
}Attachments
Step 6: Wave Direction (HELP US)
We never actually managed to measure wave direction.
However the sensors aboard the buoy should be able to do it. You are able to measure dynamic accelerations with the GY-86 Accelerometer by subtracting the affects of the gravitational force. You are also able to get the direction of this acceleration. Using the direction of buoy acceleration along with the compass value for a given position should allow you to determine wave direction. We gave it a go in the code below.
---- If someone out there could help us with this it would be amazing <3 ----
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#include "Wire.h"
MPU6050 mpu;
HMC5883L mag;
int16_t mx, my, mz;
#define INTERRUPT_PIN 2 // use pin 2 on Arduino Uno & most boards
float declination = -14.0 - (59.0 / 60.0);
// MPU control/status vars
bool dmpReady = false; // set true if DMP init was successful
uint8_t mpuIntStatus; // holds actual interrupt status byte from MPU
uint8_t devStatus; // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize; // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount; // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q; // [w, x, y, z] quaternion container
VectorInt16 aa; // [x, y, z] accel sensor measurements
VectorInt16 aaReal; // [x, y, z] gravity-free accel sensor measurements
VectorInt16 aaWorld; // [x, y, z] world-frame accel sensor measurements
VectorFloat gravity; // [x, y, z] gravity vector
volatile bool mpuInterrupt = false; // indicates whether MPU interrupt pin has gone high
void dmpDataReady() {
mpuInterrupt = true;
void setup() {
Wire.begin();
Wire.setClock(400000);
mpu.initialize();
mag.initialize();
// initialize device
Serial.println(F("Initializing I2C devices..."));
mpu.initialize();
pinMode(INTERRUPT_PIN, INPUT);
Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
devStatus = mpu.dmpInitialize();
// supply your own gyro offsets here, scaled for min sensitivity
mpu.setXGyroOffset(112);
mpu.setYGyroOffset(5);
mpu.setZGyroOffset(-15);
mpu.setZAccelOffset(1487);
if (devStatus == 0) {
mpu.setDMPEnabled(true);
Serial.print(digitalPinToInterrupt(INTERRUPT_PIN));
attachInterrupt(digitalPinToInterrupt(INTERRUPT_PIN), dmpDataReady, RISING);
mpuIntStatus = mpu.getIntStatus();
dmpReady = true;
packetSize = mpu.dmpGetFIFOPacketSize();
void loop() {
if (!dmpReady) return;
while (!mpuInterrupt && fifoCount < packetSize) {
if (mpuInterrupt && fifoCount < packetSize) {
fifoCount = mpu.getFIFOCount();
if ((mpuIntStatus & _BV(MPU6050_INTERRUPT_FIFO_OFLOW_BIT)) || fifoCount >= 1024) {
mpu.resetFIFO();
else if (mpuIntStatus & _BV(MPU6050_INTERRUPT_DMP_INT_BIT)) {
while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
mpu.getFIFOBytes(fifoBuffer, packetSize);
fifoCount -= packetSize;
// OUTPUT_READABLE_WORLDACCEL
mpu.dmpGetQuaternion(&q, fifoBuffer);
mpu.dmpGetAccel(&aa, fifoBuffer);
mpu.dmpGetGravity(&gravity, &q);
mpu.dmpGetLinearAccel(&aaReal, &aa, &gravity);
mpu.dmpGetLinearAccelInWorld(&aaWorld, &aaReal, &q);
Serial.print("Acceleration (x,y) m/s/s: ");
Serial.print(aaWorld.x);
Serial.print(" ");
Serial.println(aaWorld.y);
// Find the angle of acceleration
// double angle_of_acc = atan2(aaWorld.y, aaWorld.x);
// angle_of_acc *= 180/M_PI;
// Get compass heading
// mag.getHeading(&mx, &my, &mz);
// float heading = atan2(my, mx);
// if (heading < 0) heading += 2 * PI;
// if (heading > 2 * PI) heading -= 2 * PI;
// heading *= 180/M_PI;
// heading += declination;
// Offset angle of acceleration by the heading angle
// wave_direction = angle_off_acc + heading
Step 7: Crude Wave Energy
One definition of Wave energy is defined by:
P = 0.5 height ** 2 * period [ https://en.wikipedia.org/wiki/Wave_power].
Using our values for wave period and height, we are able to calculate wave energy like this:
#include "Wire.h"
#include "I2Cdev.h"
#include <ms5611.h>
MPU6050 mpu;
MS5611 baro;
long pressure;
double altitude, min_height, max_height, wave_height, mid_point, smudge_factor, wave_power;
void setup() {
Wire.begin();
mpu.initialize();
delay(500);
void loop() {
// for 15 seconds
wave_height = (max_height - mid_point) / 2.0;
smudge_factor = wave_height * 0.15;
Serial.print("Wave Height m: "); Serial.print(wave_height);
// for 15 seconds
if ( !started){
started = true;
else{
if ( escaped ){
started = false;
escaped = false;
// assign it
else{
else{
escaped = true;
Serial.print(" Period s: "); Serial.print(avg_period/1000);
wave_power = (0.5 * wave_height * wave_height * avg_period / 1000);
Serial.print(" Wave Power kW/m: "); Serial.println(wave_power);
}Attachments
Step 8: Water Temperature
Finally, we want to be able to measure water temperature. The DS18B20 water temperature sensor will protrude from the bottom of the buoy into the sea and the Arduino communicates with it using 1-wire.
The only modification you need to make is adding a pull-up resistor on the signal wire and then we can talk to it like this:
#include <onewire.h>
#include <dallastemperature.h>
OneWire oneWire(6);
DallasTemperature sensors(&oneWire);
float water_temperature;
void setup() {
sensors.begin();
void loop() {
sensors.requestTemperatures();
water_temperature = sensors.getTempCByIndex(0);
Serial.print("Water temperature C ");
Serial.println(water_temperature);
delay(200);
}Step 9: Thanks
Thanks for reading this tutorial, this has been the first step in building our smart buoy. Check out our next tutorial soon to see how we send and store data and use the GPS.
Part 1: Making Wave And Temperature Measurement
Part 2: GPS NRF24 Radio and SD Card
Part 3: Scheduling Power to the Buoy
Check out T3chFlicks.org for more tech-focused educational content (YouTube, Instagram, Facebook, Twitter).
![Smart Buoy [Waterproofing, Dashboards and Deploy]](https://content.instructables.com/F06/R2QW/KM7QQ3HZ/F06R2QWKM7QQ3HZ.png?auto=webp&crop=1%3A1&frame=1&width=130)
