Introduction: Smart Display Case With LEDs
About: Making and sharing are my two biggest passions! In total I've published hundreds of tutorials about everything from microcontrollers to knitting. I'm a New York City motorcyclist and unrepentant dog mom. My wo…
Today, I’ll show you how I built a smart illuminated display case for showing off your finest wares. Specifically, I built this as a YouTube Makers Secret Santa gift for Nate From The Internet. I wanted this year’s gift to balance delight with practicality, so it has two parts (and two Instructables): the LED display case with 3D printed logos, and a sturdy fabric knife roll.
I started with a locking steel and glass key storage cabinet, and customized it by adding NeoPixel LED strip and a 3D printed honeycomb storage wall (HCW), which is a great system of 3D printable parts that lets you swap in whatever hooks or shelves you need. I know Nate loves 3D printing, so while I printed a few generic mounts, I expect he’ll want to customize his to match the items he chooses to display. I removed the stock logo from the glass using some acetone.
Head over to Nate’s channel to watch him open my gift.
All the electronics for this build were provided by DigiKey, and you can shop the parts list:
  1. 1m NeoPixel strip
  2. WiFi microcontroller such as Arduino Nano ESP32
  3. 3D printer
  4. PLA filament
  5. Locking glass-front display cabinet
  6. Foam core board
  7. Ruler
  8. Cutting mat
  9. Utility knife
  10. Soldering tools and supplies
  11. Solderful breadboard
  12. Mobile device with free WLED app
  13. Step drill
  14. Safety glasses
  15. Epoxy
  16. Nitrile gloves
  17. Hot glue gun and hot glue
  18. Long USB C cable
  19. USB C AC adapter
You can also find this project on DigiKey’s maker.io. And if you’re looking to build up your skills enough to build a project like this one, check out my electronics teaching series on the DigiKey YouTube channel. We start with the absolute basics, like soldering up LED circuits and introducing critical tools, then build to more complex topics, including connecting microcontrollers to the internet, like I’m doing in this project with WLED. A big thank you to DigiKey for their continued support of my channel.
Step 1: Create Backboard
First, I had to flatten out the key hooks by smashing them down with a hammer. Then I used some five-minute epoxy to glue in some black foam core board and the 3D printed grid.
Step 2:
Next, I drilled a hole for the power cable to come through the bottom of the cabinet. I used a step drill. Ideally, you’d use a drill press for this, but a hand drill and some patience will suffice.
Step 3:
Then it was time to bring in the smart part. I used an Arduino Nano ESP32 wifi microcontroller, wired up to some NeoPixel addressable LED strip, and it’s running software called WLED. So while I did set a default color, all Nate has to do to change or animate the LEDs is join the device’s wifi access point and fire up the WLED app. He can then also add in his own wifi details so the device can be controlled over his local network.
I’m using one meter of side-emitting NeoPixel strip, and at the end, I’ve added a NeoPixel stick. The idea is for the strip to run around the inside of the frame, and the stick to light up a 3D printed logo at the center front. Because they are all the same type of pixels, I can chain them together like this. I used hot glue to install the circuit, as well as Nate’s logos, which I 3D printed.
