Introduction: Smart RGB Ikea Solbo Owl Lamp
Hello!
This is a small project to "hack" the Ikea Solbo Owl Lamp and make it a bit smarter.
Ikea Solbo Owl Lamp
Wemos D1 mini
Micro USB Cable
WS2812B RGB LED Ring with 12 LED's
Tesa TACK Adhesive Putty
Wires/dupont cables
Basic soldering iron
Step 1: Prepare the Lamp
Remove the bottom 3 screws.
Cut the side of the clips holding down the cable. One cut on the side would be enough to release the old cable, and still reuse it with the new cable.
Unclip the middle bulb socket. It's held in place by 3 clips.
Step 2: Prepare the Wemos D1
This project uses WLED to control the LED's
I believe the easiest way to flash the Wemos is by using the web installer install.wled.me
Plug in your ESP to a USB port.
Hit "Install" and select the correct COM port.
Get WLED installed and connected in less than 3 minutes!
Step 3: Wiring
Connect the LED Ring to the Wemos.
Step 4: Reassemble the Lamp
The 12 LED ring fits exactly in the center. I fixed in in place with Tesa TACK Adhesive Putty.
The Wemos can be placed on the side, the USB cable can go thru the existing clip then out thru the existing cutout.
Step 5: WiFi Setup
Use a WiFi device to connect to the access point WLED-AP using the default password wled1234.
Go to the IP 4.3.2.1 in your browser to control your lights. You should also be able to connect to wled.me if in access point mode (embedded DNS server).
To connect your WLED module to your home Wifi:
1. Click on the Config (gear) icon to edit your WLED module settings and choose "Wifi Setup".
2. For most home networks, simply enter your Wifi network's name and network password. You can also change the mDNS address for your WLED module here.
3. Click Save & Connect at the bottom of the page.
4. Reconnect your device to your home's Wifi network.
5. Check the device list in your router's user interface for the IP of the WLED device within your local network.
Step 6: Control the Lamp
For easy automatic discovery, use the WLED app.
There is also a home assistant integration available.
Have fun with the WLED software and the new lamp !
Step 7: Thank You !
Hope you enjoyed this project and if you have any questions feel free to ask.
Thank you for reading!
