Introduction: Smart Socket USB – Power on Demand
About: Electronics and DIY repair enthusiast with a casual, no-nonsense communication style. I love simple yet effective projects where creativity meets utility. A firm believer in personal growth through knowledge s…
I built a simple and efficient system to sync my soundbar’s power with my TV, eliminating unnecessary energy waste. Using a USB-powered relay (connected to the TV), the soundbar now turns on/off automatically with the TV—no smart home systems or idle power consumption needed. A practical, wired, and eco-friendly solution!
Why It Works:
- Eco-friendly: Eliminates standby power waste.
- Plug-and-play: No apps, cloud, or smart devices.
- Reliable: Mechanical activation via the TV’s USB signal.
The entire project is built with recycled parts, except for the relay board which I bought for less than 1 euro.
Reference for Purchase: 1-Channel 5V Relay Module with Optocoupler ( jumper set to high-level trigger )
Step 1: Plastic Rib Removal
Removing Plastic Ribs with a Dremel to Fit the Relay Board
Step 2: Relay Wiring & Mounting Procedure
Electrical connections
  1. Connected the +5V DC pole to the relay's input signal (IN)
  2. Secured the USB cable's +5V and GND wires to the screw terminal using ferrules (shown in white) for reliable contact
  3. Other side relay board's:
  4. Used COM and NO ( normally opened ) terminals
  5. Wired a 230V cable to the power cord
Mechanical mounting
  1. Secured the relay board in place using hot glue ( marked by arrows in the figure )
Step 3: How It Works
Simple automatic control using TV power state
When the TV is turned on, it powers the USB port → this sends a +5V signal to the relay's control pin (IN) → activating the relay → which closes the 230V AC circuit → supplying power to the electrical plug.
Step 4: Project Complete!
See this short test video, I power on a vacuum tool to verify operation. Enjoy!
