Introduction: Smart Staircase LED Lighting
For a long time, we've been turning on the lights at the beginning the staircase, just to turn them off when we reach another floor.
But instead, we built a simple system to turn them ON automatically when you are going upstairs or downstairs, just by using a couple of IR proximity sensors, a relay and an Arduino Pro Mini, to control the timing.
If you want to build your own, just follow our guide.
Step 1: Shopping List
You can optionally use a power converter (from 12v to 5v) if you want to take advantage of the 12v input to power your Arduino and sensors.
Step 2: Schema
Step 3: Arduino Code
#define IR_RECEIVER 8#define RELAY 10
void setup() { // initialize digital pin LED_BUILTIN as an output. pinMode(RELAY, OUTPUT); digitalWrite(RELAY, LOW);
// the loop function runs over and over again forever void loop() {
int sensorValue = digitalRead(IR_RECEIVER); // print out the value you read: delay(10); // delay in between reads for stability
if (sensorValue == 0 ) { digitalWrite(RELAY, HIGH); // turn the LED on (HIGH is the voltage level) delay(5000); } else { digitalWrite(RELAY, LOW);
