Introduction: Smart Street Light Using Ir Sensor With Arduino
By the way, subscribe to my YouTube channel for more projects like this. I also update my upcoming projects on Instagram.
buy me a coffee! ☕: Donate
This project is about Smart street light, street light will turn on while vehicle is passing through it.
here we are using 4 IR sensors that senses the position of the vehicle,each IR sensor controls 3 LED's. When vehicle passes by a particular IR sensor it senses the position of vehicle and gives its signal to the arduino board and it will turn on the LED's.
ADVANTAGES:
If we uses this idea and implement to it in our society it will be helpful in saving enough amount of electricity and off-course money.
Step 1: Components Required
- arduino uno
- ir sensor (4)
- 10mm LEDs (6)
- connecting wire
- foam board
Step 2: Upload the Program
download and upload the program in arduino uno
Step 3: Connect the Circuit
Connect all the components as given in the circuit diagram.
ir sensor 1 ---> 2
ir sensor 2 ---> 3
ir sensor 3 ---> 4
ir sensor 4 ---> 5
connect all ir sensor's to +5v and ground.
the positive pin of leds are connected to these pins of arduino.
led 1 ------> 6
led 2 ------> 7
led 3 ------> 8
led 4 ------> 9
led 5 ------> 10
led 6 ------> 11
and finally all ground pins of led connect to the ground of arduino.
Step 4: Build Suitable Structure
To make these poles as given in above picture, use foam board and glue.
and you may also use black chart to make a road and wooden board for the base of pole.
