Introduction: Smart Water Filtration.
This Arduino-based project addresses three critical environmental challenges: water scarcity, water pollution, and the efficient use of plant irrigation. The system collects and stores rainwater in a primary container, helping conserve freshwater resources. When needed, the water is transferred via a pump to a secondary container equipped with a filtration system, which removes dirt and harmful bacteria, ensuring clean water for irrigation. A soil moisture sensor monitors the plant’s needs, and it activates the watering system only when the soil is dry. This smart, automated solution promotes sustainable water use and healthier plant growth while minimizing waste.
Arduino uno
Relay module
Water pump
Jumper wire
alot
Water level sensors
Soil moisture sensor.
lcd
1 i2c
breadboard
The wiring diagram is attached.
Step 1: Code
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
const int soilMoisturePin = A1;
const int waterLevel1Pin = A0;
const int waterLevel2Pin = A2;
const int relayPump1Pin = 2;
const int relayPump2Pin = 3;
const int soilDryThreshold = 600;
const int waterLowThreshold = 300;
unsigned long pump2StartTime = 0;
bool pump2Running = false;
void setup() {
pinMode(relayPump1Pin, OUTPUT);
pinMode(relayPump2Pin, OUTPUT);
digitalWrite(relayPump1Pin, HIGH); // OFF
digitalWrite(relayPump2Pin, HIGH); // OFF
lcd.init();
lcd.backlight();
lcd.print("System Starting...");
delay(2000);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("W1: W2: ");
lcd.setCursor(0, 1);
lcd.print("S: P1: P2:");
Serial.begin(9600);
void loop() {
int soilMoisture = analogRead(soilMoisturePin);
int waterLevel1 = analogRead(waterLevel1Pin); // Reservoir status
int waterLevel2 = analogRead(waterLevel2Pin); // Tank status
// Print values on LCD
lcd.setCursor(3, 0);
lcd.print(" ");
lcd.print(waterLevel1);
lcd.setCursor(10, 0);
lcd.print(" ");
lcd.print(waterLevel2);
lcd.setCursor(2, 1);
lcd.print(" ");
lcd.print(soilMoisture);
Serial.print("Soil: "); Serial.print(soilMoisture);
Serial.print(" | Water1: "); Serial.print(waterLevel1);
Serial.print(" | Water2: "); Serial.println(waterLevel2);
bool pump1State = false;
bool pump2State = false;
if ((waterLevel1 > waterLowThreshold) && (waterLevel2 < waterLowThreshold)) {
digitalWrite(relayPump2Pin, LOW); // ON
} else {
if ((soilMoisture > soilDryThreshold) && (waterLevel2 > waterLowThreshold)) {
digitalWrite(relayPump1Pin, LOW); // ON
} else {
// Show pump statuses on LCD
lcd.setCursor(9, 1);
lcd.print(pump1State ? "ON " : "OFF");
lcd.setCursor(14, 1);
lcd.print(pump2State ? "ON" : "OFF");
delay(500);
