Introduction: Smart Watering
In this Arduino project tutorial we will learn how to make Smart Watering
Step 1: Required Hardware
Arduino Board - https://goo.gl/MpCaGC
Arduino Ethernet Shield - https://goo.gl/RHUufR
Soil Moisture Sensor - https://goo.gl/GsgkFs
Solenoid Valve Flow Switch 1/2 - https://goo.gl/oWVPTd
Water Flow Sensor 1/2 - https://goo.gl/n65dro
DHT11 Module - https://goo.gl/haBEmL
Relay - https://goo.gl/x8vUnV
Step 2: Connections
Step 3: Source Code
Here is the code of the arm that goes in the Arduino - Get Code
Step 4: Create Webserver
Server Script
?>//Database Connection $koneksi = mysqli_connect("krstudio.web.id","username","password","database") or die("Error ".mysqli_error($koneksi)); //Take data form table on database MySQL $sql = "SELECT * FROM greenhouse ORDER BY id DESC LIMIT 30"; $result = mysqli_query($koneksi, $sql) or die("Error in Selecting " . mysqli_error($koneksi)); //Make array $greenh = array(); while($row =mysqli_fetch_assoc($result)) { $greenh[] = $row; } //Display convert data form table identity to format JSON echo json_encode($greenh); //close the db connection mysqli_close($koneksi); //refresh 11 second ?>
Step 5: Get Application
The files of the app are available on - Google Playstore
Step 6: Testing
Now we completed all steps and make a SmartWatering
you can control using your smartphone .
Thanks for watching.
