Introduction: SmartBin
Hello everyone , i'm a student at Howest Kortrijk Belgium and I made a project called SmartBin.
It lets you automatically open the bin when you come closer to it.
It measures the weight of the bin and also how full the bin is.
-IKEA wastebin
-Raspberry pi
-2 ultrasonic sensors
-1 Loadcell
-1 servo motor
-1 breadboard
-Alot of jumper wires
-Cardboard
-A pair of scissors
-Glue
Step 1: Collecting Materials
First of all , you start by buying a bin from IKEA, you can find them everywhere and are really cheap
IoT components (min. € 45 estimated costs):
- Raspberry Pi 3 Model B +
- Servo motor SG90
- 2 x Distance sensor HC-SR04
- Loadcell HX711 5KG
- 16x2 LCD display
- A bunch of cables
Items for the housing (min. € 10 estimated costs):
- Waste bin from Ikea
- Pattex Glue
- Cardboard
- Spraypaint
Tools used for the project:
- Visual Studio (front-end development,backend development)
- PhpMyAdmin(database)
- scissors
- glue
Step 2: Find a Piece of Cardboard
then you find a piece of cardboard and place the waste-bin on top of it and cut a big hole in it the size of the waste-bin
Step 3: Cut It
Then cut in half and tape it together with some ducktape. After that you make a tiny hole in the cardboard to fit the servo motor in it and also attach a ultrasonic sensor on the back of the cardboard. Then try to make a small circle with a hole in it of a piece of cardboard, that's for the top of the bin to go up and down , after that attach some string to it and make sure it's attached to the servomotor.
Step 4: Cut Holes
You mark 2 holes around the sensor to cut in it , after that you place the sensor in the 2 holes.
On the bottom also cut 2 holes 1 for the jumper cables of the loadcell and the other one for the charge cable.
Step 5: Hide All Electronics
Now put all the electronics inside the bin and hide it with a rest over piece of cardboard.
Step 6: Attach Velcro Tape
Now attach velcro tape on the bottom of the bin and on the upper-side of the loadcell
Step 7: Electronics
When everything is connected to the cardboard and the wastebin , start making the circuit.
Step 8: Write Code and Create Website
Now that you got your circuit , start building a website and code the functionality's of the smartbin
Step 9: Database Structure
Step 10: Code
https://github.com/howest-mct/1920-1mct-project1-mjoetoe
Step 11: How Did I Proceed?
- Searched on the internet what kind of project i could make.
- Thought about what i would need to make it.
- Bought everything i needed.
- Made a sketch on paper.
- Made the circuit and tested every sensor.
- Attached everything to the waste-bin.
- Made the frontend (HTML & CSS) and linked it to the backend
