SmartPhone or IPod Touch Windshield Mount
Intro: SmartPhone or IPod Touch Windshield Mount
Using a $5 GPS windshield mount from the flea market a few "Super" magnets and some Sugru ( http://sugru.com/ ) to make a holder for my iPod Touch. By changing the hard case and attaching the manets with Sugru this should work with any SmartPhone too!
STEP 1:
I wanted to make it iPod easy to remove from the mount, so I chose magnets.
STEP 2:
I picked up a hard shell for the iPod.
STEP 3:
First I tried to glue the magnets with "Super Glue" Cyanoacryate. No luck, the curve of the hard case made it imposable to stick to a flat surface like the mount.
STEP 4:
So I grabbed an old Friend Sugru! I moulded the Sugru around the magnets and covered with plastic wrap.
STEP 5:
The plastic wrap allowed me to mould the Sugru and magnets in a uniform thickness by pushing the hard case onto a hard surface. After I removed the plastic wrap and trim the Sugru to a nice shape. Setting the case iside and allowing it to cure overnight.
STEP 6:
I added magnets to the mount.
STEP 7:
I found that I could slip the magnets into the "clip" part of the mount .
STEP 8:
And by sticking another magnet on top, I now have a flat face to add the iPod hard case to.
STEP 9:
Now I can snap my iPod into its case, and the case will stick to the windshield mount.
12 Comments
rundmcarlson 10 years ago
kentkb 10 years ago
Perhaps I will find a used device at the flea market and do a torture test.
Thank you.
grahambob68 12 years ago
kentkb 12 years ago
I looked (googled) pretty much on the subject, and did not find any warnings, in fact I turned up some "wallets" for the Blackberry that have a strong magnetic latch on them.
GPS is electronic not magnetic, I believe, but the compass... do you have to hold it flat for the compass? Perhaps it is electronic too.
I was not able to test it with every type of phone.
As my grandpa used to say: "When in doubt, throw it out" So perhaps this hack is not such a good idea given the phone you have.
Thank you for the comment.
I just wondered if you knew if magnets could cause any lasting effects.
thanks anyhow.
kentkb 12 years ago
Thank you for checking in again.
gnelson2 12 years ago
kentkb 12 years ago
Thank you for a great question!
zazenergy 12 years ago
kentkb 12 years ago
Truehart 12 years ago
kentkb 12 years ago
I looked around the net and found some discussion of this :
Magnets affect magnetic media. most cellphones do not have magnetic data media in them, just SD cards which are electric, most modern storage devices, such as SD and CompactFlash memory cards, are immune to magnetic fields. "There's nothing magnetic in flash memory, so [a magnet] won't do anything," says Bill Frank, executive director of the CompactFlash Association. "A magnet powerful enough to disturb the electrons in flash would be powerful enough to suck the iron out of your blood cells," says Frank.
That magnets damage computer chips is generally a myth. For proof, dissect a hard drive. Inside are two of the largest magnets generally found in residential homes.
Putting a piece of metal close to the phone's antenna is never a good idea since it affects the reception and may force the phone to transmit with higher power to maintain a connection with the base station.
But there is no long term damage to the phone (except, perhaps quicker draining of the battery.) As soon as the metal piece is removed from the phone's vicinity, the phone will be back to working normally.
The only magnetic thing in a cell phone is the speaker, though I moved a strong magnet around the back of my 2 iPod Touch's and a iPad, I was not able to affect the speaker sound, plus I usually use headphones, or Bluetooth.
