Introduction: Snails - Drink Slide Die
Join Instructables ( Free) and you can view this instructable on one page.
This instructable tells how to get snails drunk and out of your garden.
The snail season hits again... I watch my hard grown seedlings get obliterated over night....
Ok so I make life hard for my self by refusing to given in and use the various pellet poisons on the market... I figure its good enough to kills snails who knows how many extra arms I'll grow in a life time of that stuff.
So I had heard that snails ( Gastropods to be precise) love a good tipple of beer, can't understand why my self... so I built some Gastro ale houses around the garden and to my amazement they came in droves, we made a "killing," punters or should I say gastros shelled and unshelled slid in from miles around... And as i slept, the party raged on hour after hour until they all slipped in to oblivion..
Man you should have seen the ducks when breakfast was served the next morning ... ( see video)
Step 1: Step 2. Mk 3 Version Is In
Step 2: Mk2 Version Has Arrived
Well after much mucking bout making the mk1 snail trap, i discovered by accident there is a better way of doing - forget the mark one, jump straight to the mk 2 below...(got to keep the mk 1 version here to allow it to be and instructable...
Mk2 - take the milk bottle required in mk1, quater fill with beer, and fishing weights - and lay it in a small impression in the ground on it side... hey presto the snails will climb in...
1.) The MK 1 - outdoor - and that is the one you see in all the pictures.
What you will need;
1 two litre Plastic Milk bottle complete with cap( see image 1) ( New Zealand - or any other similar shape) OR 420g tin can - see end of this instructable
A cutting device - either scissors, or hand saw depending on the thickness of the plastic
Beer ( best brought in stubbies so you don't leave a bottle halve full)
hole in the ground
Snails from miles around
2.) ** NEW** Mk 2version , suitable for sheltered spots particluary on a deck Trap.
( commonly known as the " keep it simple stupid version, why i didnt think of this at the start version...)
All you need;
1x 1 liter plastic milk bottle ( here in NZ that means at least three sides are flat)
Beer
Fishing weight - that will fit through the opening
Step 3: Construction.
Simply remove the bottle top, lay the bottle on its flat side with the handle side up, place the fishing weight in side the bottle to hold it down and pour the beer in until its level with the opening when layed down. - Done
The Mk 1 being for the more adventrous;
(Image 2)
First cut the bottle in halve across the line shown, using scissors or a hand saw depending on the bottle type you are using.
(Image 3)
Take the base section and cut a flap, no more than three quaters of its height, crease at the join and bend up.
(Image 4)
Take the other halve of the bottle ( ensure the top is screwed on tight)
Turn the bottle halve so the cap is at the bottom and repeat the cutting and bending of a flap.
Ensure you do not cut this flap to deep - no more than say 2.5 inches in total length
Step 4: Assemble
Take the Capped top section of the bottle - invert it again.
Dig a hole in the garden deep enough to accept the upside down bottle top and allow the flap to angle down and contact the dirt - so it now becomes a ramp. (Best to slightly bury the first halve an inch of the flap)
Take the bottom section of the bottle, alight the flaps and place it over the tops section as a lid, ensuring the walls of the part in the ground is inside the lid. The flap now becomes a handy veranda for keeping the rain off the drinkers...
(image 6)
shows the new snail bar assembled out of the earth
Grab your favourite cheap Beer that your mate gave you last week but you wouldn't be seen dead drinking... ( or do as I did and tell the shop assistant you just want real cheap beer because you are going to open a pub for the snails in your garden....) Lift the lid - pour it in and re cap.
Step 5: The Cleaner..
(image 6)
Business was a little slow on the first night, but it had well and truely picked up by the second...
(image 7)
On the second night the turn over steadly increased, and has continued to rise, i guess word spreads at a "snails pace around these parts"
Step 6: And Alternative to Beer...?
So what do the snails like the most? is it the sugar? the fermenting? the hops?
love to hear if you stumble upon any recipes that lure just as well.
Step 7: Making the Trap From Tins
I have now made the same trap out of several different bottles of similar shape - including a dishwasher powder bottle - and that is a great one - very strong and totally ideal.
here is my latest addition using tin cans.
You will need:
-- a pair of cutters that can handle tin cans with ease - i used aviation snips ... (image 1)
--- Two 420g (image 2) or matching tin cans
In the same way as we did for the milk containers - we are going to cut to "ramps" in the base can, and "two verandas" to shelter the ramps in the top can, before slotting them together.
Step 8:
Step 9: The Lid
Next mark out to cut lines approximately 1cm to the left and right of your marks above ( this allows the lid veranda's to be slightly larger than the ramps)
Cut in the same way as you did for the base can - this time cut bout 2 inches and fold flaps out just under ninety degrees to the can wall
Step 10: Prepare to Connect
Then fold out about 1 cm of the top of each upright on the base can ( see image 6) so that they hold the top can on firmly when connected
Step 11: Connection
pour in the beer as for the milk bottle version and place out doors - among the plants -the advantage of this one is it has a flat bottom and can sit with out having to dig it in.... Ensure the ramps are in contact with the ground.
