Introduction: Snake Game Pad
The purpose of creating and playing the Snake game pad which is made by arduino is to train your brain's agility and instinct that which you would find out it is quite interesting and hard where there are no up-down buttons. Well, which I would say that people who would like to train their agility can use this small technology for example; especially like old people and adults.
We'll be implementing Snake on a breadboard, an OLED screen and other arduino materials. People have certainly made tinier snake players, but this specifically uses a breadboard, removing the need to design PCBs or solder.
Here are the simply supplies you need:
Arduino Nano2
reasonably high resistors (1kOhm)
Breadboard(A tiny one would be just fine)
2 Pushbuttons
22 AWG solid core wire
128 x 64 OLED
Step 1: Start Assembling
Follow the pictures and see how it is assemble. if you know how to assemble an arduino project before, it will be much easier to assemble. If you don't know where the wires you should put from the button to the Arduino Nano, check it out from the internet.
Step 2: Test and Check
Here are the program codes
#include
#include #include
//DISPLAY THINGS #define OLED_RESET 4 // Reset pin # (or -1 if sharing Arduino reset pin) #define OLED_ADDRESS 0x3C // I2C address of the display. #define SCREEN_WIDTH 128 // OLED display width, in pixels #define SCREEN_HEIGHT 64 // OLED display height, in pixels
//BUTTON THINGS #define LEFT_B_IN A0 #define LEFT_B_OUT A2 #define RIGHT_B_IN A1 #define RIGHT_B_GND A3 #define RIGHT_B_OUT 13
//GAME OPTIONS
#define WIN_POINTS 20 #define CYCLE_INTERVAL 500 #define BUTTON_INTERVAL 400
unsigned long previousTime = 0;
//---------DISPLAY STUFF---------
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins) Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
//Draws a square on the 21x10 board //(A 128x64 board reduced to 126x60, each element is 6x6) //x is between 0 and 20 inclusive //y is between 0 and 9 inclusive //thing: 0 = erase, 1 = snake, 2 = food //Could've used a switch statement here... void drawSquare(byte x, byte y, byte thing) { if (thing == 1){ display.fillRect(6*x+2,6*y+3,4,4,WHITE); return; } if (thing == 2){ display.drawRoundRect(6*x+2,6*y+3,4,4,1,WHITE); return; } display.fillRect(6*x+2,6*y+3,4,4,BLACK); }
//---------SNAKE STUFF---------
//Coordinate struct //With the size of the game board (21x10), you could technically shrink it to //1 byte, but I don't quite know how to do that yet. typedef struct { byte x; byte y; } coord;
//THE SNAKE //#Apparently snake[] took up so much space that it interfered with the OLED //#Keep it a reasonable size. coord snake[100]; byte snakeLength = 2; short directions[4][2] = {{1,0},{0,1},{-1,0},{0,-1}}; short dirIndex = 0;
coord foodCoord;
//Initializes the snake with an initial length of 2 //and initial direction right. void makeSnake() { snakeLength = 2; snake[0] = {1, (byte) random(0,10)}; snake[1] = {0, snake[0].y}; drawSquare(snake[0].x,snake[0].y,1); drawSquare(snake[1].x,snake[1].y,1); dirIndex = 0; }
//Modify direction according to button press void redirect() { unsigned long tempTime = millis(); bool R = false; bool L = false; //Listen for button presses while (millis()-tempTime < BUTTON_INTERVAL) { if (digitalRead(LEFT_B_IN)){L = true;} if (digitalRead(RIGHT_B_IN)){R = true;} } //Ignore double presses and non presses if (R == L){ return; } //If right, increment direction index if (R){ dirIndex++; if (dirIndex > 3){dirIndex = 0;} return; } //If left, decrement direction index dirIndex--; if (dirIndex < 0){dirIndex = 3;} }
//Moves the snake bool moveSnake() { //Calculate the new coordinates int x = snake[0].x+directions[dirIndex][0]; int y = snake[0].y+directions[dirIndex][1];
//If out of bounds, exit and lose. if (x > 20 || x < 0 || y > 9 || y < 0) { return 1; }
coord newHead = {byte(x),byte(y)}; //Draw the new head drawSquare(newHead.x,newHead.y,1); //Did we land on food? / Does the new head line up with the food location? bool onFood = (newHead.x == foodCoord.x && newHead.y == foodCoord.y); //Shift all the snake coords back to make space for the head for (int i = snakeLength; i != 0; --i) { //If the new head contacts any snake coord, exit and lose if (!onFood && newHead.x == snake[i].x && newHead.y == snake[i].y) { return 1; } snake[i] = snake[i-1]; }
//If nothing wrong, set the new head of the snake. snake[0] = newHead;
//If no food, erase tail if (!onFood) { drawSquare(snake[snakeLength].x,snake[snakeLength].y,0); } //Else dont erase tail, increment length of snake, //and put a new food else { snakeLength++; putFood(); } return 0; }
//Puts a new piece of food on the game board. void putFood() { tone(11, 440, 500); //buzzer or speaker frequency
bool foodOkay = false; //Make sure the food doesnt fall on top of the snake while (!foodOkay) { foodCoord = {byte(random(0,21)),byte(random(0,10))}; foodOkay = true; for (byte i = 0; i < snakeLength; ++i) { if (foodCoord.y == snake[i].y && foodCoord.x == snake[i].x) { foodOkay = false; break; } } } drawSquare(foodCoord.x,foodCoord.y,2); }
void setup() { //Serial.begin(9600); // SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally if(!display.begin(SSD1306_SWITCHCAPVCC, OLED_ADDRESS)) { //Serial.println(F("Oh no")); for(;;); }
//Random numbers randomSeed(analogRead(7));
//Set up the buttons //Left button pinMode(LEFT_B_IN, INPUT); pinMode(LEFT_B_OUT, OUTPUT); digitalWrite(LEFT_B_OUT,1);
//Right button pinMode(RIGHT_B_IN, INPUT); pinMode(RIGHT_B_GND, OUTPUT); pinMode(RIGHT_B_OUT, OUTPUT); digitalWrite(RIGHT_B_OUT,1); digitalWrite(RIGHT_B_GND,0);
//Set up the title screen display.clearDisplay(); display.setTextSize(3); display.setTextColor(WHITE); display.setCursor(20,5); display.println(F("SNAKE")); display.setTextSize(1); display.setCursor(26,40); display.println(F("Hit L to play")); }
//Game loop void loop() {
display.display(); //Wait for user input while (!digitalRead(LEFT_B_IN)){}
//GAME SETUP //Set up borders display.clearDisplay(); display.fillRect(0,0,128,2,WHITE); display.fillRect(0,62,128,2,WHITE); display.fillRect(0,0,1,64,WHITE); display.fillRect(127,0,1,64,WHITE);
//Make the snake and place the food makeSnake(); putFood(); display.display(); bool win = false; delay(800);
//Start game for(;;) { //Every cycle if (millis() - previousTime > CYCLE_INTERVAL) { previousTime = millis(); //Check for direction change redirect(); //Self contact/Out of bounds condition if (moveSnake()) { break; } if (snakeLength == WIN_POINTS+2) { win = true; break; } display.display(); } }
if (win) { display.clearDisplay(); display.setTextSize(2); display.setTextColor(WHITE); display.setCursor(0,5); display.println(F("YOU WON :)")); } //Show lose screen else { //Flash the screen display.invertDisplay(true); delay(400); display.invertDisplay(false); delay(400); display.invertDisplay(true); delay(400); display.invertDisplay(false); delay(400);
//Loss text display.clearDisplay(); display.setTextSize(2); display.setTextColor(WHITE); display.setCursor(0,5); display.println(F("YOU LOST:(")); } display.setTextSize(1); display.setCursor(0,30); display.print(F("Donuts Eaten: ")); display.print(snakeLength-2); display.println(); display.println(); display.println(F("Hit L to play again")); }
