Introduction: Snapchat Hands Free Hack
Greetings, dear Snapchaters,
in this tutorial I want to show my simple solution for a "big problem" with Snapchat. For all you, who are using a Snapchat, you know very well that you need to hold your finger on the big grey button to record a video and snap it. iPhone has a solution for this (something with gestures bla bla), but I have not found a simple solution for Android phones, so I was thinking why not to solve this problem by using a hardware, not software.
Take a look at the other steps and you'll see what I meant.
I actually never needed to snap something and have both hands free, but I was planning to attach a phone to quadcopter and using most light equipment to trigger recording in mid air, I have never seen someone doing that, so why not to give a shot.
Step 1: Parts
All you'll need is:
-audio jack
-soldering iron (or not even that if you tie your wires together)
-coin
-wire
-electrical tape
Step 2: Connecting the Circuit
Actually, main idea is to use ground connection from your headphones slot, it will simulate a press with a finger.
Usually green wire is a ground (-) and the other two are just left and right headphone, so connect the green wire with some longer one.
After you have done that, use electrical tape to make a contact between coin and wire, you can solder it too if is possible..
Make something like a stick from electrical tape, you'll use that as a switch, it will be located between coin and a screen. Idea is, that when you want to start recording just remove this peace of tape. You can use some wire or a string attached to it and then pull, be creative. :)
