Introduction: Sneaky Hidden Pocket Hole Jig (Concept)
Why aren't all pocket hole jigs made like this? This of course is a very rough prototype but I hope you like the concept. I'd love to hear your feedback! If there is anyone out there that has any advice where to go from here I would really appreciate it.
I've had this idea for a quite a while now. It stemmed from my video tip of "How to hide a screw".
Step 1: Where the Idea Came From "How to Hide a Screw"
I got the idea for the hidden pocket hole jig from my my "How To Hide A Screw" tip. This tip basically involves using a chisel to bevel up a small section of wood, adding your screw underneath and then gluing the bevelled up wood back down to give a perfect grain and a hidden screw.
I started to think of other applications for this tip as it proved really popular and people found it very useful. From this I turned my attention to pocket hole jigs. Was there a way to hide pocket hole screws in this way. I think I have the solution.
Step 2: How the Hidden Pocket Hole Jig Would Work
My very rough prototype is a basic wooden block plane I bought from Amazon. It has one slight alteration. I drilled a pocket hole screw guide hole into the back of it. So the idea is to use the block plane to bevel up a section of the wood.
Clamp it in place to stop it from moving.
With it clamped in place you can go ahead and drill your pocket hole.
The clamp and jig can then be removed.
You can then secure your screw in place. This works exactly the same as any other pocket hole screw joinery.
Step 3: Hiding the Hole & Screw
To prevent there just being a hollow hole beneath the wood I think its a good idea to add a plug that is already available to buy along with the pocket hole screws. Adding wood glue as you would normally secures it in place.
The bevelled up piece of wood can then be folded down and glued in place. This completely hides the screw and gives a perfect grain match.
I think it would be simple to add blade like a block plane to existing pocket hole jigs. It would also be a simple addition to existing block planes to add a pocket hole jig to its body. I'd love to hear your feedback on this idea. What do you think?
4 Comments
2 years ago
A very clever combination of techniques.
I love it but probably wouldn't bother with the plug.
Excellent, I hope you make some money out of it.
Reply 2 years ago
Cheers Karl!
2 years ago
That's an interesting idea :)
Reply 2 years ago
Thanks Penolopy!
