Introduction: Snoopy Air Tag Keychain
Do you ever misplace your keys? With the invention of the Apple AirTag, that is avoidable. However, carrying a boring AirTag on your keys or other personal objects is lame. Why not make it more enjoyable? By bringing your favorite childhood animated characters into something useful that you carry with you in your day-to-day life.
https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.ameede.net%2Fsnoopy-h002705-file-stl-free-download-3d-model-for-cnc-and-3d-printer%2F&psig=AOvVaw2CI8EIByJM-WDLZrz2qvh-&ust=1747767015295000&source=images&cd=vfe&opi=89978449&ved=0CBcQjhxqFwoTCNDy1-ebsI0DFQAAAAAdAAAAABAE.
-The material used for the project was PETG
-SolidWorks was the program used to create the part
-3d Printer
-Pliers
https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.thingiverse.com%2Fthing%3A4178842&psig=AOvVaw2CI8EIByJM-WDLZrz2qvh-&ust=1747767015295000&source=images&cd=vfe&opi=89978449&ved=0CBcQjhxqFwoTCNDy1-ebsI0DFQAAAAAdAAAAABAU
Step 1: The Beginning- Creating the Base
Start off by sketching the front face of the house you will have to use various lines in order to get the shape you will then extrude the sketch to create a 3D model of the previous 2D sketch.
Step 2: Creating the Roof Sides
On step two your focus is on creating the door entree and the roof sides. You will create one side then mirror the other in order to save time.
Step 3: Adding Detail & Creating Snoopy
On step three you will mainly focus on creating detail around the house giving it that wooden look, along with the detail that you will be creating around the house you will also create a plane centered mid-plane on the base in order to convert your 2D sketch of snoopy into a 3D one you will extrude snoopy then convert entities in order to have him sitting at the top of the roof. You will also create a small, extruded rectangle on the front face that you will use later.
Step 4: Creating Further Detail on Snoopy
On step four you should have a visual image of how your product is going to turn out this step focuses on creating detail onto snoopy like his eyes, collar, and nails you will use the extrude feature to create these minor details.
Step 5: Last Touches to Product
We are almost done!! On step 5 you will create an extruded cut through Snoopy's nose using the "through all option" on SolidWorks; you will also then create a cut on the back face dimensioned to that of the dimensions of an air tag you will want to make the dimensions a bit bigger just to ensure the air tag fits. You will also now use the small rectangle from step one you will use the text feature to create name Snoopy on the rectangle and then extrude it.
Step 6: Final Product
Congratulations you are all done!!! You can now print out your product and enjoy.
