Introduction: Snowflake Trophy
I've decided to make this because it seemed cool.
https://www.onshape.com/en/
Step 1: Sketch 1
Create a sketch of the snowflake. The numbers are in inches. The vertical line in the middle will be your mirror line.
Step 2: Design
Create your design on ONE side of the vertical line. You will mirror that design to the other side.
Step 3: Circular Pattern
Use the circular pattern tool. Set it to 6X and copy the pattern around the circle
Step 4: Extrude the Snowflake
Finish sketch and extrude the design to 0.125 inches. Make sure that the extrude is symmetric. Designs will vary.
Step 5: Sketch the Base
Create a sketch. Make a rectangle below the snowflake that's 0.6 inches high and 1.1 inches wide. Mirror the rectangle to the other side to make it symmetrical.
Step 6: Extrude the Base
Extrude the base by 1 inch, and make sure its symmetric.
Step 7: Lettering (1)
On one side of the base, place a sketch write a text that says "#1 First Place".
On the other side of the base, place another sketch and write any text that you would like. For my case, I wrote "Instructables Contest 2022".
Size of texts will vary.
Step 8: Extrude the Letters
Extrude the letters on both sides by 0.05 inches.
Step 9: Sketch the Supporting Base
On the underside of the snowflake, create a rectangle with a width of 0.18 inches and a height of 0.74 inches, making sure that it reaches the base AND the snowflake. Do the exact same on the other side of the snowflake.
Step 10: Extrude the Base
Extrude both of the bases by 0.05 inches, and make sure it's symmetrical.
Step 11: Finalize
That's it! Now just choose any color you'd like. The customization is completely up to you.
