Introduction: Snowflakes Earrings Jewelry Making Tutorial
Here’s something cute for kids and teens to wear - a colorful Snowflakes Earrings! Suitable for beginners, learning simple wrapping and looping techniques you’ll be able to create your own variation of the snowflakes earrings. The earrings measures 2 inches in diameter, but cutting the wires longer you can also use it as a pendant.
Materials & Tools:
3 pcs 0.8mm (20ga) x 5cm (2 inches) wire
0.3mm (28ga) x 38cm (15 inches) wire
Some seed beads
Round nose pliers
Flat nose pliers
Wire cutter
Materials & Tools:
Some seed beads
Round nose pliers
Flat nose pliers
Wire cutter
Step 1:
Prepare 3 pieces 20ga x 2 inches copper wire and cut 0.3mm (28ga) x 15 inches long. Pick one 20ga wire and wrap your 0.3mm wire 2 to 3 times at the center.
Step 2:
Pick another 20ga wire and wrap again.
Step 3:
Pick up the last 20ga wire and wrap again.
Step 4:
Wrap for the 2nd time, securing all 3 20ga wires. When you're done wrapping, cut of excess wire. Adjust the wires to ensure the knot is place at the middle.
Step 5:
Slide in some seed beads and create a loop with the excess wire.
Step 6:
Repeat Step 5 on all 6 wires and you're done! Hope you like it ♥
This is just a quick tutorial but there's a more detailed step by step FREE PDF Copy that you can DOWNLOAD FOR FREE
In the free pdf copy you'll find great tips on how to properly and neatly wrap the wire.
