Introduction: So Easy MicroPython - ThingsBoard, IoT Cloud Platform
*** Just add 2~3 lines, then your MCU will be an IoT device of ThingsBoard enabled***
from MyREST_TBChain import myThingsBoard
my = myThingsBoard(key="YOUR_DEVICE_TOKEN")
my.send({'temperature': 27.6, 'humidity': 68})
*** This is a very useful library I designed to let your MCU upload and download data to/from ThingsBoard Cloud platform in very easy and fast way. Just like the codes above, your MCU will send out data of temperature and humidity to ThingsBoard. ***
*** Before next demonstration, you should have your account on the cloud platform, we will not take more time to introduce it step by step since anyone can easily get help from official website ***
Step 1: Upload Libraries to Your MCU
First, You need to upload the libraries to your MCU board:
- MyREST_TBChain: A specific function library for accessing data on ThingsBoard platform
- MyWifi: A basic library for WiFi connection (Optional, if your code already make the MCU connect to WiFi)
*** If you have no idea how to upload File to your MCU, read my another article "So Easy MicroPython - ESP8266/ESP32 MCU File Management" first.
*** If you are interested in MyWifi library or no idea how to use it, read my another article "So Easy MicroPython - My WiFi Connection"
Step 2: Example 1: Upload Data to ThingsBoard Platform
# Connect to WiFi, it cab be omitted if your MCU already get on WiFi in your existing codes
from MyWifi import myWifi
my_wifi = myWifi("YOUR_WIFI_SSID", "YOUR_WIFI_PWD")
my_wifi.connect()
# Only add these 3 lines, then your MCU can upload data to ThingsBoard platform
Step 3: Example 2: Get User Token From ThingsBoard Platform
my_wifi.connect()
# Only add these 3 lines, then your MCU can get authorization token from ThingsBoard
my = myThingsBoard()
print("My ThingsBoard JWT Token:", my.getAuthToken("YOUR_TB_USER", "YOUR_TB_PWD"))
*** You MUST have a JWT Token released by ThinsBoard, before reading data from it. You can ignore this example, if you already have one.
Step 4: Example 3:Read Data From ThingsBoard Platform
my_wifi.connect()
# Only add these 3 lines, then your MCU can read data from ThingsBoard
print('\n\nGet data :', my.read("temperature,humidity", "YOUR_TB_DEVICE_ID", "YOUR_TB_TOKEN"))
Step 5: That's So Easy, Hope to Help a Little Bit !
Posted by Yungger
If it help you, and want to give some encouragement, just go HERE 😘 😘 !!
