Sociable Recumbent Trike
Intro: Sociable Recumbent Trike
The Two’Strike is a cool project I built a while back. This instructible is not really so much an instructible as it is a “feeler’ to see if there is enough interest to go to the considerable effort required to product a quality set of plans and instructions for producing your own version. If I get enough interest, I will gather the remaining construction pics, dimensions, parts list, etc and put together a how-to manual that will let you build Two’Strike with only basic shop tools and a small welder. If you are interested, leave me a comment or message me with your contact info so that I can let you know when the plans are done!
STEP 1: The Design Criteria and Final Result
The project started when my wife complained that it was hard to talk while riding our upright tandem. I had built several recumbents and wanted to build a recumbent tandem, so I decided to build a sociable trike (side-by-sides are actually called “sociables”).
I had some design criteria when I started. It needed to be less than 48” wide at its widest point so I could ride on wide sidewalks and bike trails in addition to the road. Because we pedal at different cadences, I wanted both sides to have independent gears and be completely independent of each other (i.e. either side could pedal, or not, and change gears without affecting the other rider). I thought it would be nice if either side could ‘captain,’ and ideally, the captain change could be made ‘on the fly’. The design had to be comfortable for long rides, stable in all conditions, and rideable with only one rider when needed. I also had thoughts of adding a tiny gas motor, or electrical drive at a later date. I wanted he design to be light and cool looking, not like a “old folks ride”. I wanted suspension on at least the front axle to save our backs on rough roads. It needed to be aerodynamic, but still high enough to be seen by cars and easy to get in/on. I think we accomplished all of the goals. The bike is fast and fun. It draws a crowd everywhere it goes. It is comfortable tooling along with walkers and flying down hills. It is adjustable for a wide range of rider sizes. The suspension on the front wheels makes the ride smooth and easy. Each rider has control of his own front and intermediate gears and can select his range from 21 ratios. The final drive is selected from the center handlebar and controls an additional 36 ratios. Of course, there are many duplicate or near duplicate ratios, but in theory, there are 756 ratios for each rider! This allows a wide ratio with gears low enough to climb the side of a mountain, if needed, or tall enough that your muscles are the only limit to the top speed! The comfortable riding position lets you see all the sights without straining you neck and the cockpit layout give you options of cup holders, phone mounts, or a place for your wife’s book! If this sounds like a project you would like, let me know. I have developed simple ways to guarantee that the front end geometry is correct and very easy to build. I make final frame alignment a snap (and that is really hard to do otherwise!). It is a big project to develop plans and instructions on this type of project, but I am willing if you are!
24 Comments
aledoctors 7 months ago
kopuga 1 year ago
aledoctors 1 year ago
I would love to try to replicate it. Do you have plans and details of your plan?
How do you make one rider independent of the other?
I have endless questions. I don't know where to start.
Thanks for inspiring us and hopefully you will post the construction plans.
Touinchette 4 years ago
Your project of sociable recubent trike is exactly what we want to made with my husband. We have had the same thinking about this and, like your wife, I want to be side by sides and have the possibility to have independent gears and be completely independent each other.
That is why I am very interrested to know how you had made precisely your trike.
If you have more photographies or if your have finaly developped plans and instructions, I’d like to see them.
Thanks you very much for your help to build our own sociable trike project.
Databanks 7 years ago
I'd be interested in seeing more photos and details of how you built it. Can I also suggest adding support on the outside of each front wheel. I've read quite a few posts and most recommend both sides of an axle having support. Up to you, I'd be interested to know how the two front wheels have held up only supported on one side. This looks interesting to build
ryoung29 5 years ago
The single sided axles have not been any issue at all. They are 36 spoke BMX rims with 14 MM axles. They have lasted for years and years with no ill effects.
NicolasF76 6 years ago
I would love to discuss our design with you. I would appreciate if I could call you.
My email is Nfraser@alumnos.uai.cl
Thank you very much
jakehamilton79 7 years ago
More info, please! :)
Eddie_can_fix_it 8 years ago
im going to build a travel camper my gf and i can live in. I have many ideas but i cant draw for the life of me. Not sure if you can help but i like your Sociable trike, i want something similar to pull the camper, but at the same time disconnect so we can ride and have some space to ourselves. At the moment we are more or less homeless staying in our friends garage, i was wondering if you knew what material would be the lightest but durable for the pavement and dirt roads, and affortable. I have access to bikes and parts due to my best friends bike shop. If you can help me out id appreciate it more than you know, if you email me will you make the subject urgent. Thanx, Eddie
I'm wondering if a modification of this and https://www.instructables.com/id/Building-a-Recumbent-Bamboo-Trike-Frame/ would work for you. Bamboo being light weight and this design here being great for 2 people.
Rapturee 8 years ago
Count me in! I too know time is often precious. And although it would be difficult to put together a plan/project like this however...if you could even put together a basic set with some really great pictures.-We'll do the rest! Thank you so very much a-head-of-time! :{)
aphix 8 years ago
bradleypowell 8 years ago
eveready2b 8 years ago
I would love to have all the info needed to build and ride this sociable.
villager 8 years ago
You've peeked my interest and quite a few other. So please turn the feeler in to an ible. Thank you
Ryu_ookami 8 years ago
seriously would love to get hold of the plans for the entire build
crazy like a Fox 8 years ago
Can I also beg for some more detailed pics of the individual parts? I'm really curious about the front end suspension that you mentioned.
aphix 8 years ago
Want to add another voice into the, "would love to see this whole process" pile.
pjhrtr 8 years ago
I'd love to see detailed plans! Let my vote be x1,000 and you're likely to be featured for the design efforts. Sounds like a very valuable product as well!
wavey davey 8 years ago
