Introduction: Social Distancing Arduino Monkey
This project was designed to help with social distancing. This monkey can be worn pin/necklace that lets you know when someone is getting too close for social distancing.
Parts:
- ATTiny 85
- HC-SR04 Ultrasonic Sensor
- LED (red)
- 330 Resistor
Step 1: Code and Pin Connection
The setup is fairly simple. Just connect the ultrasonic sensor and the led to the attiny. Detail are in the code below. I recommend testing it on an Arduino Uno then moving to the ATTiny85.
* Original Ultrasonic code by Rui Santos, https://randomnerdtutorials.com
* Modified by Peter Fox Flick for attiny, peterfoxflick.com
* VIDEO: https://youtu.be/dF5E5jsWSZA
Ultrasonic sensor Pins:
VCC: +5VDC
Trig : Trigger (INPUT) - Pin 0
Echo: Echo (OUTPUT) - Pin 1
GND: GND
LED Schematic
Pin 2 -- LED -- 330 Resistor -- GND
int trigPin = 0; // Trigger MOSI 0
int echoPin = 1; // Echo MISO 1
int ledPin = 2;
long duration;
long dist[3];
int pos = 0;
void setup() {
//Define inputs and outputs
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(ledPin, OUTPUT);
void loop() {
// The sensor is triggered by a HIGH pulse of 10 or more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
digitalWrite(trigPin, LOW);
delayMicroseconds(5);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Read the signal from the sensor: a HIGH pulse whose
// duration is the time (in microseconds) from the sending
// of the ping to the reception of its echo off of an object.
duration = pulseIn(echoPin, HIGH);
// Convert the time into a distance
dist[pos] = (duration/2) / 29.1;
pos = pos > 2 ? 0 : pos + 1;
//use a rolling average to help prevent spikes
long sum = 0;
for(int i = 0; i < 3; i++){
sum += dist[i];
long avg = sum / 3;
if(avg < 200){
digitalWrite(ledPin, HIGH);
} else {
digitalWrite(ledPin, LOW);
delay(500);
