Introduction: Soft Rocking Chair Bottom
When my husband bought this antique rocker I feared that the bottom would bust out and before long it did. For months we stuffed pillows in it for a bottom. The time had come to fix it. It is not hard to upholster something like this if you have the right materials. It is supremely satisfying to use scraps I salvaged from other projects.
Step 1: Materials
I used
scrap wood
a scrap of upholstry fabric
foam I salvaged from a mattress I took apart
a jigsaw
a staple gun
a utility knife
scissors
hardware
a screw driver and or drill (not pictured)
Step 2: Cut Away the Old
The old bottom was harder to cut than I expected. I finally realized that it was much easier to cut if I flipped the reed back. The underside was for some reason much easier to cut with the utility knife.
Step 3: Mark the Wood
I traced the underside of the scrapwood but then realized that I needed to make it slightly larger so it wouldn't fall through and so it would fit inside the reed trim I decided to leave in. I drew around my original outline to allow for this space.
Step 4: Cut
I used a jigsaw to cut it and then tested to see if I got it right.
Step 5: Trace and Cut Foam
I traced the scrapwood shape onto the foam and cut the foam. I didn't even have to unroll it.
Step 6: Cut the Fabric
I laid my wood and foam on the fabric and made sure there was plenty of room for stapling it. I probably cut it too big but better too much than too little.
Step 7: Staple
Like stretching a canvas, I pull the middles first. We want it tight but not too tight. I continue to staple out from the middle of each side until I reach the corner. It is helpful to flip it over and look to see how lumpy the edges are looking. This is how I folded the corners.
Step 8: Trim
I had alot of extra and I don't want that hanging down so I trimmed off what was excess.
Step 9: Drill on Hardware
I first drilled holes in the wood on the chair and then added the hardware. This was hard wood so I stripped a few screws in the process.
Step 10: Screw on the Seat
I marked the holes first and then drilled holes to help me out. Finally I screwed in the last four screws and there you have it.
