Introduction: Soil Moisture Content Measurement Using Esp32 and Thingsio.ai Platform
In this tutorial I am going to explain about reading of the moisture content in the soil by using esp32 and then sending the values into the thingsio.ai IoT cloud platform.
Step 1: COMPONENTS
Hardware Components:
1. esp32 development board
2.Soil sensor
3.Jumper Wires
Software:
1. Arduino IDE
2. Thingsio.ai
Step 2: CONNECTIONS
Soil Moisture Sensor----------------------esp32 Board
VCC---------------------------------------3V3
GND--------------------------------------GND
A0----------------------------------------VP
Step 3: CODING:
#include <WiFi.h>
#include <WiFiMulti.h>
#include<WiFiClientSecure.h>
int count=0,i,m,j,k;
int t;
int sensor_pin = A0;
int value ;
//////////////////////////////////////// ALL DECLARATIONS for CLOUD //////////////////////////////
const char* host = "api.thingsai.io"; // OR host = devapi2.thethingscloud.com
const char* post_url = "/devices/deviceData"; // OR /api/v2/thingscloud2/_table/data_ac
const char* time_server = "baas.thethingscloud.com"; //this is to convert timestamp
const int httpPort = 80;
const int httpsPort = 443;
const char* server = "api.thingsai.io"; // Server URL
char timestamp[10];
WiFiMulti WiFiMulti;
// Use WiFiClient class to create TCP connections
WiFiClient client;
/////////////////////////////////////// TIMESTAMP CALCULATION function///////////////////////////////////////
int GiveMeTimestamp()
{unsigned long timeout = millis();
// WiFiClient client;
while (client.available() == 0)
{if (millis() - timeout > 50000)
{client.stop();
return 0;
while (client.available())
{ String line =
client.readStringUntil('\r');
//indexOf() is a funtion to search for smthng , it returns -1 if not
found int pos =
line.indexOf("\"timestamp\""); //search for
"\"timestamp\"" from beginning of response got and copy all
data after that , it'll be your timestampif (pos >= 0)
{int j = 0;
for(j=0;j<10;j++)
{timestamp[j] = line[pos + 12 + j];
void setup()
{Serial.begin(115200);
Serial.println("Reading From the Sensor ...");delay(2000);
// We start by connecting to a WiFi network
WiFiMulti.addAP("Wifi_name",
"Wifi_Password");Serial.println();
Serial.println();
Serial.print("Wait for WiFi... ");
while(WiFiMulti.run() != WL_CONNECTED) {
Serial.print(".");delay(500);
Serial.println("");
Serial.println("WiFi connected"); Serial.println("IP
address: ");Serial.println(WiFi.localIP());
delay(500);
void loop()
{{/////////////////////////////////////// SEND THE QUERY AND RECEIVE THE RESPONSE///////////////////////
value= analogRead(sensor_pin);
// value = map(value,550,0,0,100);
Serial.print("Mositure : ");Serial.print(value);
Serial.println("%");delay(1000);
Serial.print("connecting to ");Serial.println(host); //defined upside :- host = devapi2.thethingscloud.com or 139.59.26.117
///////////////////////////////////// TIMESTAMP CODE SNIPPET /////////////////////////
Serial.println("inside get timestamp\n");if (!client.connect(time_server, httpPort))
{return; //*-*-*-*-*-*-*-*-*-*
client.println("GET /api/timestamp HTTP/1.1"); //Whats this part
doing, i didnt get
client.println("Host: baas.thethingscloud.com");
client.println("Cache-Control: no-cache");
client.println("Postman-Token:
ea3c18c6-09ba-d049-ccf3-369a22a284b8");client.println();
GiveMeTimestamp();
//it'll call the
function which will get the timestamp response from the serverSerial.println("timestamp receieved");Serial.println(timestamp);
Serial.println("inside ThingsCloudPost"); String PostValue =
"{\"device_id\": 61121695918, \"slave_id\": 2";PostValue = PostValue + ",\"dts\":" +timestamp;
PostValue =
PostValue +",\"data\":{\"MOIST\":" + value
+"}"+"}";Serial.println(PostValue);
/* create an instance of WiFiClientSecure */
WiFiClientSecure client;
Serial.println("Connect to server via port 443"); if
(!client.connect(server, 443)){
Serial.println("Connection failed!"); } else {
Serial.println("Connected to server!");/* create HTTP request */
client.println("POST /devices/deviceData HTTP/1.1");
client.println("Host: api.thingsai.io");
//client.println("Connection: close");
client.println("Content-Type: application/json"); client.println("cache-control:
no-cache");
client.println("Authorization: Bearer
eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.IjVhMzBkZDFkN2QwYjNhNGQzODkwYzQ4OSI.kaY6OMj5cYlWNqC2PNTkXs9PKy6_m9tdW5AG7ajfVlY");
client.print("Content-Length: ");client.println(PostValue.length());
client.println();
client.println(PostValue);
//////////////////////////////////POSTING the data on to the cloud is done and now get the response form cloud server//////////////////
Serial.print("Waiting for response
"); while
(!client.available()){delay(50); //
Serial.print(".");}
/* if data is available then receive and print to Terminal */
while
(client.available()) {char c = client.read();
Serial.write(c);
/* if the server disconnected, stop the client */
if
(!client.connected()) {Serial.println();
Serial.println("Server disconnected");client.stop();
Serial.println("////////////////////// THE END
/////////////////////");delay(3000);
Step 4: OUTPUT:
The Output of the code is shown.
Step 5: GRAPH
This is the graphical representation of the values which are read from the sensor.
Step 6:
Here is the complete video of the project. Thank You.
