Introduction: Soil Moisture Detector
班級姓名:
9D 林心蓉 Flora Lin
簡介: For my Arduino project, I wanted to make something meaningful that can actually help me solve the problems that I face in my life. I thought about the things I struggled with and the first thing that came in my mind is how I always forget to do things and one of those things is watering my plants. So I made a device that would automatically remind me to water my plants if/ when the soil gets too dry. This way the device would not only be a project for school but also can be really useful in my life too
來源: http://www.circuitstoday.com/arduino-soil-moistur...
I didn’t completely follow the tutorial, as you can see, the circuit and codes are different, I only used this website to get ideas and see the materials I needed. I added the alarm that would actually remind me to water the plant.
6.材料清單:
Materials needed for this project are:
1k resistors x1
LED light x1
10k piezo Buzzer x1
Soil moisture detector set x1
Assorted wires
Arduino Leonardo x1
Breadboardx1
Step 1: Procedure for Making the Device Pt.1
CIRCUIT
Step 1 In case the picture wasn’t clear enough,
GND >> -
5v >> +
for the moisture sensor:
AO >> GND
DO >> A0
VCC+ >> +
For the buzzer:
+ >> pin 6~
For the LED light:
Anode >> Resistor >> pin 7
Cathode >> -
Step 2: Procedure for Making the Device Pt.2
PACKAGING
Step 1: find a box that fits the board
Step 2: Measure a hole on the top of the box to stick the sensor out
Step 3: cut out the hole
Step 4: find and measure a hole big enough to fit the USB cord
Step 5: cut out the hole
Step 6: also on the top of the box, cut a smaller hole to put the LED light through
Step 7: place the device in the box with the USB cords plugged in and seal the box
Step 3: Procedure for Making the Device Pt.3
TESTING
Step 1: find some dried out soil
Step 2: place the sensor in the soil and check that the buzzer and LED lights work properly
Step 3: pour water in the soil and check if it properly detected the moisture and stopped the alarm
Step 4: Conclusion + Final Product
In the end despite all of the frustrating times where I would get stuck on a line of coding or when I had to start over because it did not work, I was pretty proud of the device that I made. It was not only useful, but I also learnt a lot on the way, I pushed myself to do more even when I didn't want to and I improved my computer skills a lot during the duration of this task.
The video of my device actually working is here:
THANK YOU !!!
