Introduction: Solar Hat
Today I will be making a solar hat. What you will need, a small DC motor, a 2 1/2 half inch solar panel can get this out of a solar garden lamp with about 3 volts of power,some wire, a baseball cap, tin foil, a propeller. tools... Hot glue gun, soldering gun (optional) please vote for this project if you like it.:):):) Thanks hope you have FUN!!! :):)
Step 1: Build It Then Use It
Now you just add glue where is needed and make sure the polarity on your motor to the polarity on your Solar panel is correct so your motor spins right way. Otherwise, the motor might not blow air on you. Glue your tin foil around on the top of your hat pretty much any tin foil will do. Now just follow the photos and video that I have supplied and logic.
